Thread: Smokes at idle!!!!
Results 1 to 20 of 50
  1. #1 Re: Smokes at idle!!!!
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Ok I pulled all the plugs and #2 is horrible but then #4 has a slight hint of white also. So the back is the suspect unfortunately. My oil level was also down a tad as well.
    As for the valve seals they look to be in place. I did not remove the springs or anything but tried moving the seals with a screw driver on #2 and 4.
    Compression test was also performed
    #1--150--#2--145--#3--150
    #2--160--#4--140--#6--135
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  1. When coil pack module is connected the wire harness gets hot and smokes *UPDATE*!!
    By SuperchargedIntrigue in forum General Tech Discussion
    Last Post: 05-11-2015, 09:48 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. burning coolant:( smokes when i shut it down
    By gtcoup in forum General Tech Discussion
    Last Post: 01-31-2011, 12:08 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
