wheel well it is for sure, take the wheel off have a pan handy, take lines off, the pump will drain when the lines come off.
watch out for the knock sensor wire clipped to the pump, un clip it or you'll break it.
you also need a GM power steering pulley pulley. free rental at the parts store. swap the pulley once the pump is in your hands.
Thanks to ll that replied !! Good advice. I will go thru the wheelwell. It is tight getting the pump in and out thru the clearance over the steering linkage. But looks to be just enough..... Rather not mess with those coolant elbows, been there done that ....
