Hello all, first post on this forum and I'm glad to have found an active GP community is still out there. I've been a member of other GP boards for over 10 years. I own a 2000 GTP coupe and I'm experiencing an overheating issue that I can't seem to figure out. After a lot of searching and trying several things, I'm about out of answers so I'm hoping for some help from this board.
For starters some background...
2000 GTP
141K miles
180 t-stat
PRJ intercoooler
3.2 pulley
1.8 comp pro mags
TOG headers
Tuned myself via PowrTuner
Various other supporting mods
LIM gaskets replaced with metal design at around 60K miles
I've been driving my car for many years and tens of thousands of miles under this configuration. The car has always run in the 170-190 degree range even idling in traffic on really hot days. The temp gauge never reached the halfway 210 degree mark.
A few weeks ago, the temps started going much higher than normal. It would hit 210 and more so I knew something was off. On a couple of occasions I've had to pull over as the gauge started to creep towards the 3/4 mark.
I started by examining the obvious by checking coolant level, t-stat, pump, leaks, etc...
I noticed that the temps seem to rise around town and driving in traffic, but looked fine at speed so I started to suspect that I have an issue with the cooling fans.
So far I have validated that both fans work by supplying battery power to them. With 12v directly from the battery, both fans spin at high speed.
I checked the 3 under-hood relays, one is a 5 pin and the two others are 4 pin and they all checked out well.
I swapped the ECT with the one from my other 3800 powered car.
What I don't understand is how the fans are supposed to operate on my car. Do they operate at different speeds? Is one a high speed and another a low speed? I noticed that the driver's side fan spins fast, but the passenger side fan spins very slow.
When I turn on the A/C, should both fans spin at high speed?
I have the fans tuned to kick on at lower temps vs stock since I'm using a 180 t-stat and I have validated that they do turn on, but once again, the driver's side fan spins fast and the passenger side spins slow.
I don't know if this is normal operation. If it is normal, what else could be the cause of my overheating issue?
Thanks!
