Thread: Time for an intercooler. Need suggestions
Results 1 to 5 of 5
  1. #1 Time for an intercooler. Need suggestions
    Aug 2014
    North Alabama
    Well I noticed today my upper intake gaskets are leaking pretty bad. Car is a 2000 GTP btw. I already have some speed daddy's and a Gen V that I've been needing put on. I figure this is as good of a time as any to put the Gen V on it. Also planning to intercool it while I'm at it. So what FSIC do you guys recommend? I'm not biased to any particular brand. Just looking for one that's fairly easy to install with little to no clearance issues. So what do you guys suggest? Thanks
    2000 GTP coupe. Wizaired intake. 3.4 pulley, Overkill tune, and Speed Daddy's waiting to be put on.
  2. #2 Re: Time for an intercooler. Need suggestions
    Kemmerer, Wyoming
    there is no other intercooler I would consider than this one:
    http://www.grandprixforums.net/threa...erCharger-3800
    all of the intercoolers are going to be a good amount of work. I'm not sure how much you know, so I'll give you more info than you may or may not need. there are basically 5 components in an intercooler system. the intercooler core, the front mount heat exchanger, the pump, the wiring and the hoses. mounting the intercooler itself is probably the easiest part because it just sits in between the supercharger and the lower intake manifold. you will need modified fuel rails and a longer supercharger belt, and you will need to adjust something so the belt clears the coil pack mount. the heat exchanger bolts to the frame in front of the radiator, and depending on which heat exchanger you get, you may need to make the brackets yourself. there are a lot of different ways and places to run the coolant lines and pump.
  3. #3 Re: Time for an intercooler. Need suggestions
    GTP Level Member
    Pittsburgh
    agreed, Ed's Intercooler is top notch, and more fins per inch in the core than any competitor
    2003 SSEi,
  4. #4 Re: Time for an intercooler. Need suggestions
    I break stuff selliott's Avatar
    Kansas City
    I agree I had one and not only is the craftsmanship excellent it works amazing well
  5. #5 Re: Time for an intercooler. Need suggestions
    i also got one of eds ic's got it used, works perfectly. best part is the pcv holes all work on both sides of it. no modding needed for the pcv to work properly.
  1. Intercooler lower intake manifold without intercooler
    By GPChief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 02:35 PM
  2. time for a new car - suggestions?
    By Bio248 in forum Off Topic Discussion
    Last Post: 01-21-2014, 12:28 PM
  3. Time to refresh tired suspension! Suggestions?
    By rcdino1978 in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2011, 05:46 PM
  4. Time for new Struts, and maybe springs. Suggestions?
    By Space Dynamics in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2009, 02:35 AM
  5. Time to buy tires, suggestions?
    By Space Dynamics in forum Tires & Wheels
    Last Post: 10-02-2009, 09:38 AM
