Thread: Engine takes a long time to rev down
Results 1 to 20 of 23
  1. #1 Engine takes a long time to rev down
    SE Level Member Lou and Blue's Avatar
    Oct 2015
    Baldwin, NY
    I have a 3800sc series 2 (96) and it's attached to a manual trans and when I push in the clutch and let off the gas , the engine doesn't seem to want to rev down. It's like it's freewheeling with no compression. When I rev it in neutral in the driveway it also doesn't want to rev down . I was advised that it was prob a dirty tb so I cleaned it spotless but it is still the same . Any suggestions?
    Thanks in advance !
    Founder / President Long Island's Little Fiero Owners Club (L.I.L.F.O.C.)
    "Blue" <= '85 Fiero GT 3800sc series 2
    "Boo" <= '81 Delorean DMC-12, VIN #5835, Stock PRV engine, Peugot 604 Intake manifold, Exhaust headers, Anti-3rd brake light
  2. #2 Re: Engine takes a long time to rev down
    best to post a vid so we all can see what its doing.
    iirx we covered the cables and vac leaks already didnt we?
  3. #3 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    Yeah, I'll try to post a video today.
    Thanks scotty !!!
  4. #4 Re: Engine takes a long time to rev down
    Kemmerer, Wyoming
    what is it normally supposed to rev down to?
  5. #5 Re: Engine takes a long time to rev down
    hangover park IL
    Manual pcm file?
    If it's still an automatic file do you have the range switch wired so that the computer thinks it's in neutral or in Drive?
    ~James~ Psychotic Gearhead
  6. #6 Re: Engine takes a long time to rev down
    hes got a tuned pcm from a fiero guy. id have to think its set up for a 4 speed.
    its a 3800 swapped set up.
  7. #7 Re: Engine takes a long time to rev down
    hangover park IL
    I don't know of too many 96 PCM files that are very well mapped. But I do know that the 9899 Regal and GTP files are.... so if they don't have access to the throttle follower gain for the IAC.....
  8. #8 Re: Engine takes a long time to rev down
    i think the engines a 96, not sure what year bin or pcm hes running. its a canned tune. ive offered up help if he needs it being hes somewhat local.
    if you dont have a matching maf installed for the year bin file your running, that could make it act a fool too.
  9. #9 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    I didn't know about the matching year MAF sensor. Supposedly the computer is from a regal but it's programmed to be a 2000 Grand Prix I think I can email the guy and ask him
  10. #10 Re: Engine takes a long time to rev down
    the pcm is not a issue, but you need to call and see if its a 2000 bin, then if it is you'll need a tb and maf. iirc the 99-2000 maf is different then a 96. in the way the maf fits only pretty much.
  11. #11 Re: Engine takes a long time to rev down
    and then there the change the maf file to a 96 maf in the tune too. the other option. if your using the 96 maf.
  12. #12 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    The Maf im using is from an unknown car (i can contact the guy I bought the tb from) I bought a throttlebody with all centers but I only took the MAF off and put it on my tb my Maf was broken physically crushed.
  13. #13 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    If that's the only issue I guess I COULD live with it.
  14. #14 Re: Engine takes a long time to rev down
    hangover park IL
    Did it have a small Tower about the length of your pinky joint. Or did it have a large Tower similar to your thumb
  15. #15 Re: Engine takes a long time to rev down
    hangover park IL
    Why would it be flashed with a 2000 file when you should not have need of any of the digital cluster outputs...aside from the pita enhanced obd2 with all the additional onboard tests that non emissions Vehicles find annoying when tuning
  16. #16 Re: Engine takes a long time to rev down
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I know my car will rev hang a little if I bog it and the idle air has to take over from a stop. Then 1st to 2nd it rev hangs when I clutch because it still hasn't closed. Doesn't do it normally tho, does it search for idle at all normally on startup?
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  17. #17 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    Quote Originally Posted by Turbocharged400sbc View Post
    sorry for not understanding , but what is meant by "tower"? And when you say "did it have", what is "it" that you are referring to..
  18. #18 Re: Engine takes a long time to rev down
    hangover park IL
    the tower is the portion of the sensor that goes into the air flow path, youll see two thin wire/sensor elements, the small tower has them inside a hole in the tower, the "big" tower has a 90* airpath to the sensor filaments.
    you cant put a big tower into a small tower throttle body, but you can put the small into the later model years "big" tower TB, it just doesn't like it since there's no ducted metered airflow path past the sensor filaments which can cause annoying low load/airflow drivability problems
  19. #19 Re: Engine takes a long time to rev down
    Oct 2015
    Baldwin, NY
    Ijust dug out the old one that I removed and it's hard to tell what kind it is but it has the same number on it (as part of the plastic /not engraved into the plastic) that the one I replaced it with does AFH50M-04
    the engrave numbers on them are different the old one is 5Y13 and the new one installed in the tb is C7Z13
  20. #20 Re: Engine takes a long time to rev down
    hangover park IL
    okay so is the tower the size of your pinky or the size of your whole thumb?
  1. Takes Long To Start Up
    By GrandPriest24 in forum Introductions/Noob Questions
    Last Post: 01-27-2013, 08:32 PM
  2. Trans takes a long time to shift from 1st to second, one it does it is good
    By hampshire32000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-09-2011, 03:47 PM
  3. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  4. Engine takes too long to idle
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-18-2009, 12:07 AM
  5. my car takes a long time to switch frm gear 1 to 2.
    By krazyog1 in forum 04+ Specifics
    Last Post: 03-19-2009, 12:02 AM
