Thread: EGR screw/bolt removal.
Results 1 to 8 of 8
  1. #1 EGR screw/bolt removal.
    Feb 2016
    Central New Jersey (Mercer County)
    Installing speed daddy headers. I don't want to delete egr. Can't seem to get this bolt screw thing out. My ratcheting wrench won't fit in the little loop between the pipe and manifold, and a regular one doesn't seem to have enough turn space. How did you guys take yours out. Thanks in advance
  2. #2 Re: EGR screw/bolt removal.
    the bolt is on the back of the exhaust manifold, if you have not figured that part out yet.
    i used a 10 mm deep socket on a 1/4" drive ratchet aka a little ratchet and socket. flip it on from behind and get to wrenching it off.
  3. #3 Re: EGR screw/bolt removal.
    Bolt size depends on year. Newer years are a 13mm. But yeah.. get in there and you'll get it.
  4. #4 Re: EGR screw/bolt removal.
    Feb 2016
    Alright thanks guys. I appreciate it.
  5. #5 Re: EGR screw/bolt removal.
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I seem to remember my factory egr to manifold bolt being a goofy 13mm 12-point head. My ratcheting wrench was too big to fit, needed to use a regular one with a tiny turn at a time.
  6. #6 Re: EGR screw/bolt removal.
    That's interesting. I have never seen a 12 point on one of them. Only six. But 13 or 10 were the two possibilities
  7. #7 Re: EGR screw/bolt removal.
    Knoxville, TN
    I'll snap a picture if I can find it in my bucket o w-body bolts. I always ditch it in favor of a 6-point head, though. I believe both times I ran into the 12-point, they were on my 04 Impalas.
  8. #8 Re: EGR screw/bolt removal.
    Oct 2011
    Toledo, OH
    Mine was just a normal 13mm like all the others. Other than #2 plug boot, that was my only hold up. Couldn't get torque on it and when I finally got it free I had to unbolt it 1/12 of a turn at a time. FYI if you didn't notice yet, the SD EGR line doesn't sit flush with the EGR port on the 04+. You'll need a half inch ID washer to fill the gap.
    7"
  1. 2003 Rear License Plate screw/bolt
    By msubully82 in forum General Grand Prix Discussion
    Last Post: 11-03-2015, 01:04 PM
  2. How to remove this weird screw/bolt
    By GrandPrick97 in forum General Tech Discussion
    Last Post: 12-27-2014, 08:05 PM
  3. 1997 gp glove box screw/bolt size
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-27-2013, 04:07 PM
  4. Head bolt removal?
    By REDCRAPGP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2012, 05:10 PM
  5. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
