Thread: 2003 GTP new to me. Advice?
Results 1 to 20 of 28
  1. #1 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Daughter is picking up a 03 GTP. It has 200k and I was going to do some prevent stuff no mods no maintenance history seems to run well. And I have had 2 other GP's in the fleet. 00 NA and an 07 SC
    Here is my thinking
    Change oil and filter
    New fuel filter
    New air filter
    New cabin air filter
    Flush and fill radiator check upper and lower hose and replace plastic elbows with metal elbows. ( green coolant )
    New spark plugs (should I stick with iridium or go w copper, I like the long life.)
    Change transmission fluid and filter (pan drop and clean add an extra magnet)
    Change supercharger oil
    Any thought on stuff to add or delete from list.
  2. #2 Re: 2003 GTP new to me. Advice?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I have a set of ac delco iridium plugs that I had in my car before I had to go to colder plugs when I cammed and mod'd it they are like new
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: 2003 GTP new to me. Advice?
    Good start.. I'd add a shift kit to the list, check that the lim has been done too. Plus wires are also cheap enough unless the ones on it look rather new,
    04 Comp G.
  4. #4 Re: 2003 GTP new to me. Advice?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    A transgo shift kit. The best place for that is ebay. I got mine for $35. Then get plug wires as well like previously stated. Other than that the list looks good.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  5. #5 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    What kit do I order? Will the 03 GTP have the HD tranny?
  6. #6 Re: 2003 GTP new to me. Advice?
    Jul 2015
    Jamestown, NY
    Yes and they are the same
  7. #7 Re: 2003 GTP new to me. Advice?
    Donating Users timboku's Avatar
    Montgomery, IL
    You can buy these and put hids in them.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  8. #8 Re: 2003 GTP new to me. Advice?
    Montgomery, IL
    Sorry wrong post
  9. #9 Re: 2003 GTP new to me. Advice?
    Apr 2014
    South Haven, MI
  10. #10 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    ^^^^ thanks for the link. I might just try that. Tough to find any complaints in any of the reviews and seems straight forward to install
  11. #11 Re: 2003 GTP new to me. Advice?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Also, the SC oil may need to be changed.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  12. #12 Re: 2003 GTP new to me. Advice?
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by EJOUIE View Post
    That is always a good idea. Mine is new to me and I'm about to do mine just because I have no idea when it was done last and neither did the past owner.. Haha
  13. #13 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Changed the SC oil last night. Still hits you every time how bad that stuff smells coming out of there. Was brownish not low at all. Not sure if it was the first time in 199 K or not but I feel better that it's done.
  14. #14 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Also cleaned her up good. Parts should arrive this weekend to start on the list.
    Cleaned and conditioned the leather seats. Not sure that was ever done. Might have to do that multiple times to soften up the pass and back seat. Any product recommendations. I used some meguiers stuff.
  15. #15 Re: 2003 GTP new to me. Advice?
    Nov 2015
    Olive branch, MS
    There's a leather product called voodoo by surf city that helped mine a lot. I found it at Wal-Mart
  16. #16 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Picked up the voodoo and that and the meguiers have softened the seats looks like multiple applications may be in order. Got most of the list done. Added the shift kit and seems to have quickened the shifts. Still have to do an axle or 2 and hubs. Have a vibration on acceleration and both shafts move a little so starting w the driver side. Both hubs move a little. Again the driver side more so starting there.
    Also have an appt for the dealer to do the valve cover gasket recall next week. They will only do the front. And wanted 400 bucks to do the rear. Who only does 1 gasket? Guess I will do the rear later if I want to tackle that.
  17. #17 Re: 2003 GTP new to me. Advice?
    Nov 2015
    Olive branch, MS
    It might be better just to do all the gaskets at one time yourself.. That's what my plans are any way
    I don't really like going to dealerships for recalls because they always half-a** is and mess up more things than they fix.
  18. #18 Re: 2003 GTP new to me. Advice?
    If I got paid $400 to do valve cover gaskets, I'd be rich.
  19. #19 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Yep and that's just 1. Stealerships!
  20. #20 Re: 2003 GTP new to me. Advice?
    GTP Level Member
    Oct 2014
    Driver side axle and hub done. Pass side later this week.
  1. My 2003 GT
    By ShadowSwept in forum Members Rides
    Last Post: 10-04-2012, 12:32 PM
  2. 2003 gp gt
    By Shane D in forum Audio, Security & Visual Electronics
    Last Post: 05-16-2012, 07:56 AM
  3. Wtb: 2003 gtp pcm
    By brandonl2000 in forum Wanted To Buy - Parts
    Last Post: 02-11-2012, 01:10 AM
  4. 2003 GT vs 2003 mitsubishi eclipse GTS
    By kjohnson in forum Track Sessions and Kills
    Last Post: 04-01-2009, 11:27 AM
