Thread: Oil pressure light came on help....
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Oil pressure light came on help....
    Feb 2008
    How does it do when you rev it? How long has it been doing this?
    You could have a blockage in the pickup tube or a broken pressure bypass spring in the adapter. There could be just that much wear in the bearings. What about your balance shaft? Is it still in? Heck, you may be as unlucky as I was and have a spun cam bearing.
    Whatever the problem is, 6-7 PSI is well below the recommended minimum pressure. I would say don't run it until you get the pressure issue figured out.
  2. #22 Re: Oil pressure light came on help....
    its only been doing it for a week or so as far as i can tell. i usually dont even drive the car far enough for the oil to get hot enough to even do that. i was planning on running some seafoam through it to make sure nothing was blocked up by a bunch of crud over time.
    when i rev it the oil pressure goes up like usual, but it is still low compared to before. balance shaft is in there, but disabled.
    when you guys spun your cam bearings it was low regardless of throttle?
  3. #23 Re: Oil pressure light came on help....
    Aug 2008
    SOUTH TEXAS
    I dont know about my first motor.
    But on the second one,i had the same symptoms you are having.
    But when i gave it gas mine would up.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  4. #24 Re: Oil pressure light came on help....
    if sea foam doesnt cure it then im not going to be happy.
  5. #25 Re: Oil pressure light came on help....
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Wow, Bio, you're not having a good day.
    2001 Buick Regal LS - Almost Stock
  6. #26 Re: Oil pressure light came on help....
    i know right, it has been running strong for a year and now this crap happens. WEAK SAUCE.
  7. #27 Re: Oil pressure light came on help....
    Feb 2008
    Yea, when my cam bearing went, my pressure was doing the same thing. 4 PSI at idle and up to 50 with a rev or under load.
  8. #28 Re: Oil pressure light came on help....
  9. #29 Re: Oil pressure light came on help....
    Feb 2008
    ^^^ I'm jealous...
  10. #30 Re: Oil pressure light came on help....
    homie, you got ported heads. you win either way, haha. ive never had my car run without knock either, beat me there too?
  11. #31 Re: Oil pressure light came on help....
    Feb 2008
    That's only because I had 6 weeks to port them while my car was down late last summer. The blasted thing's down again with 3 chipped pistons, now... lol Woohoo paycheck-eaters!
  12. #32 Re: Oil pressure light came on help....
    im with ya there. my car eats all my money and doesnt give it back.
  13. #33 Re: Oil pressure light came on help....
    GTX Level Member 02BlueGT's Avatar
    Hoffman/Schaumburg, IL
    It gives back fun and speed though?
    2002 GT...CAI, Headers, Special Eddition two-tone leather interior added, HUD added, 12" Brake Upgrade, ZZP strut tower bars, gmpp sway bars, poly motor mounts, -6an braided SS fuel hoses , Hptuned, Headers, Top Swaped, 50lb inj, E85, 3.4
    I've got Boost!! Top swap Quesions? Click Here
  14. #34 Re: Oil pressure light came on help....
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  3. tire pressure light
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2008, 03:01 AM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. tire pressure monitoring system light
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-02-2008, 09:13 PM
