its only been doing it for a week or so as far as i can tell. i usually dont even drive the car far enough for the oil to get hot enough to even do that. i was planning on running some seafoam through it to make sure nothing was blocked up by a bunch of crud over time.
when i rev it the oil pressure goes up like usual, but it is still low compared to before. balance shaft is in there, but disabled.
when you guys spun your cam bearings it was low regardless of throttle?
I dont know about my first motor.
But on the second one,i had the same symptoms you are having.
But when i gave it gas mine would up.
