Thread: fuel pressure gauge
Results 1 to 3 of 3
  1. #1 fuel pressure gauge
    Jan 2009
    sacramento ca
    I would like to install a pressure sensor for my psi gauge. local parts stores don't know what I am talking about. can anyone help me to do this? I've looked for tees, found none,any idea where to put this set up? also looked for a y fitting for my oil gauge and found none. want to keep sensor for dash light %. I even asked for a sandwich plate, they all looked deers in headlights!
    please help me oh great ones, I pay ouhms to you
  2. #2 Re: fuel pressure gauge
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  3. #3 Re: fuel pressure gauge
    SE Level Member BlackGS's Avatar
    Central Jersey
    I bought this sender:
    vGauges
    I don't have stock rails, but you could get an adapter as mentioned in the other thread.
    My sender output is wired into my EGR connection (my EGR was removed when I installed intercooler). I monitor the fuel pressure through scanning software. If you have a gauge that accepts 0-5v signal, then you could wire directly to the gauge.
    Here's a pic of the sender installed.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  1. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
  2. Connection of Manual Oil Pressure Gauge
    Last Post: 07-25-2008, 03:47 PM
  3. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  5. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
