Thread: Oil pressure light came on help....
Results 1 to 20 of 34
  1. #1 Re: Oil pressure light came on help....
    just to use this thread and not to make another...
    has anyone ever had an oil pump go out? nothing mechanically changed on my car and there is NO fluids in the oil. ive got low oil pressure now, about 6-7 psi at idle when the car is hot. i just cant seem to understand how an oil pump goes out or if it is even a common thing that can happen or if my oiling holes are just clogged up.
    anyone? suggestions? comments?
  2. #2 Re: Oil pressure light came on help....
    Aug 2008
    SOUTH TEXAS
    Mine was reading the same.
    And it was a broken cam bearing causing it.
    The motor wasn't knocking or anything.
    The oil pump would show good oil pressure if you give it gas though.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  3. tire pressure light
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2008, 03:01 AM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. tire pressure monitoring system light
    By uti grand prix in forum General Tech Discussion
    Last Post: 10-02-2008, 09:13 PM
