Thread: Abs code C1218
Results 1 to 4 of 4
  1. #1 Abs code C1218
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Has any had this code and it was something other than a bad ground.?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Abs code C1218
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    C1218 - Pump Motor Circuit Shorted to Voltage or Motor Ground Open
  3. #3 Re: Abs code C1218
    Jan 2009
    ny
    Quote Originally Posted by Burbman View Post
    Thanks, I know what it means I have a code reader. Using Google, some people had grounding issues that caused the problem. Just trying to find out if anyone here had this problem and what they dId to take care of it.
  4. #4 Re: Abs code C1218
    Jan 2009
    ny
    My Google search revealed it possibly being a ground issue. Today I cleared the code multiple times and it immediately came back. I removed the electrical connector, cleaned it electric parts cleaner, I also cleaned the ground wire and where it attached to the body. I started the car, the abs and service traction lights didn't stay illuminated. I checked for codes and there weren't any. I hope this takes car of the problem, I'll keep you guys posted.
  1. Replies: 8
    Last Post: 02-21-2015, 07:08 PM
  2. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  3. Code P1629 and Code P1573
    By gmsprincess in forum General Tech Discussion
    Last Post: 03-16-2013, 03:39 PM
  4. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  5. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
