Thread: Sensor question
Results 1 to 2 of 2
  1. #1 Sensor question
    Apr 2016
    Dalton, GA
    There is a sensor that is in between the trans and engine the wire goes into the wire harness that connects to the back of the power steering pump. What is this sensor for the wire broke off up in the wire harness some where. I need to run a new wire.
  2. #2 Re: Sensor question
    rear knock sensor harness is what you broke.
    near where it was clipped to the p/s pup is a plug, un plug it and replace or patch the busted wire with solder and shrink tubes.
    you will need some long ass needle nose pliers to get the plug back on the knock sensor.
  1. MAP Sensor Question
    By 2002GP1 in forum General Grand Prix Discussion
    Last Post: 05-16-2013, 05:26 AM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Question about a MAF sensor.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 08:45 PM
  4. Sensor question,,,,,,I think
    By the955iman in forum General Tech Discussion
    Last Post: 04-22-2009, 04:14 PM
  5. o2 sensor question
    By TJs97 in forum General Tech Discussion
    Last Post: 06-22-2008, 09:26 PM
