My fuel trims have always run high in the impala, around 7-13 while driving around town and sometimes up to 15 while idle. When I turn my ac on they go up to 16.4 and stay there. I had p0170, or whatever the vac leak code is, come once last week, I cleared it, removed my evap, replaced all the vac lines with rubber ones, the code hasn't come back but nothing else has changed. It doesn't stall out and it doesn't run rough just sucks in a lot of air. I've sprayed brake clean, didn't have carb cleaner, all around and nothing has changed. Only thing that's been replaced on the motor is the throttle body, replaced with a stage 1 ported, but I had this problem before too.
My k&n intake I can hear sucking air in like crazy, like when I start the car for the first time in the morning, when I'm accelerating. I'm thinking the MAF might be bad and not actually a vac leak. I have a new o2 on the way.
The lim gaskets haven't been done on this motor either so maybe there?
I want to tune but the car is mostly stock and I want to fix this first.
