Thread: Exhaust Leak
Results 1 to 13 of 13
  1. #1 Exhaust Leak
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Shop doesn't have a smoke machine and can't find my exhaust leak. I know it's leaking near the firewall and thought it was the flex. They said the flex is good and it may be a cracked exhaust manifold. Should I buy a fog machine or use Seafoam to find the leak.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Exhaust Leak
    buy a can of seafoam, follow the directions all but putting it in your oil. when you fire it up the exhaust will smoke like crazy, you can stuff rags in the tail pipes to slow the exhaust to force the leak to really show its self too.
  3. #3 Re: Exhaust Leak
    Quincy, Mass
    Mine leaks at the catback connection and it sounds like it's coming from the flex. Right now it looks like everything is right but I can hear the leak and see some tiny holes in the paste.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Exhaust Leak
    Jan 2009
    ny
    The factory didn't use a flex, so why does the aftermarket use them?
  5. #5 Re: Exhaust Leak
    there is a stock flex and it does blows out.
  6. #6 Re: Exhaust Leak
    Quincy, Mass
    The flex from the factory is different but it's there right at the manifold connection.
  7. #7 Re: Exhaust Leak
    Jan 2009
    ny
    e.
    I used Seafoam and found the front down pipe gasket leaking. I'm going to replace it and see how the car runs. The leak sounded small, so I hope this may be it and I hope it's the only leak.
  8. #8 Re: Exhaust Leak
    thats likely the factory flex leaking. new down pipe time.
    get under it, fire it up cold and feel the area with your hands for hot air hitting your hands. the gasket hardly fails there.
  9. #9 Re: Exhaust Leak
    Jan 2009
    ny
    Factory downpipe long gone, it's a zzp downpipe. It was smoking between the rear mani and the downpipe. I could also see the Seafoam leaking in that area as well.
  10. #10 Re: Exhaust Leak
    got ya, i thought it was stock still.
  11. #11 Re: Exhaust Leak
    Jan 2009
    ny
    The leaking gasket was from Zzp, when I purchased the downpipe. I replaced it with a factory gasket I had laying around.
  12. #12 Re: Exhaust Leak
    Quincy, Mass
    I hate 2 bolt flanges..
    Sent from my iPad using Tapatalk
  13. #13 Re: Exhaust Leak
    Jan 2009
    ny
    Here you can see where the gasket was leaking, this is the gasket I got from ZZP when I purchased the downpipe. I had some factory gaskets laying around, so I use them.
  1. exhaust leak somewhere?
    By tom5170 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2016, 08:50 PM
  2. Exhaust leak
    By LHRxXD3adXx in forum Introductions/Noob Questions
    Last Post: 11-14-2014, 09:59 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
