Thread: Vacuum leak help
Results 1 to 13 of 13
  1. #1 Vacuum leak help
    Quincy, Mass
    My fuel trims have always run high in the impala, around 7-13 while driving around town and sometimes up to 15 while idle. When I turn my ac on they go up to 16.4 and stay there. I had p0170, or whatever the vac leak code is, come once last week, I cleared it, removed my evap, replaced all the vac lines with rubber ones, the code hasn't come back but nothing else has changed. It doesn't stall out and it doesn't run rough just sucks in a lot of air. I've sprayed brake clean, didn't have carb cleaner, all around and nothing has changed. Only thing that's been replaced on the motor is the throttle body, replaced with a stage 1 ported, but I had this problem before too.
    My k&n intake I can hear sucking air in like crazy, like when I start the car for the first time in the morning, when I'm accelerating. I'm thinking the MAF might be bad and not actually a vac leak. I have a new o2 on the way.
    The lim gaskets haven't been done on this motor either so maybe there?
    I want to tune but the car is mostly stock and I want to fix this first.
    No more GP 04 Impala SS Indy:
  2. #2 Re: Vacuum leak help
    Quincy, Mass
    So the p0171 came back today. sitting at the red light my ltft are 16.4, car is not struggling or anything though. When the light turns green my ltft will go down to like 8 if I stay on it but will go back up to 15-16.4 when I let off the peddle.
    What do you guys think the cause could be? I don't believe it's a vac leak since it doesn't run rough.
  3. #3 Re: Vacuum leak help
    sounds just like a vac leak really.
  4. #4 Re: Vacuum leak help
    Quincy, Mass
    Figured it out today. Did a smoke test with a buddy, not leaks. Unplugged the maf (should've done that a week ago) and the fuels dropped to where they are supposed to be. Drove home with it unplugged and all was good! Gunna put in the spare I have otherwise just get a new one.
    Anything wrong with the hitachi mafs? Can get them for $80 on Amazon.
  5. #5 Re: Vacuum leak help
    oem junk yard mafs are the cheapest route to go. im on a used maf for the last 6 years now. best 40 bucks i ever spent lol
  6. #6 Re: Vacuum leak help
    Quincy, Mass
    Well it's not the maf... Took a test ride and it all went back the same with the spare maf. Gunna do the lim gaskets. Gen V here we come
  7. #7 Re: Vacuum leak help
    Quincy, Mass
    Coolant plugs on the lim are 1/4" npt right?
  8. #8 Re: Vacuum leak help
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    yes, I'm doing two LIMs right now lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  9. #9 Re: Vacuum leak help
    Kemmerer, Wyoming
    Quote Originally Posted by Swiggles View Post
    I thought people used 1/8th inch taps, but it doesn't really matter. I used a 3/8" tap on the last one I did and a 9/16" drill.
  10. #10 Re: Vacuum leak help
    Kemmerer, Wyoming
    last time I thought I had a vacuum leak it ending up being the wrong injector flow rate and a bad calibration for a stock maf sensor. one thing I took away from that situation was that a home made smoker kit could be used to find the leak, like using charcoal and mineral oil inside a sealed off metal can that has a hose to vent the smoke out of and some compressed air to push the smoke out.
  11. #11 Re: Vacuum leak help
    Oct 2014
    Frederick, MD
    what also works is if you have a buddy that vapes...lol
  12. #12 Re: Vacuum leak help
    Quincy, Mass
    I just read Bill's how to mod a lim again and yup it's 1/4
    I have stock injectors, stock table, did touch any of the injector tables. I do have new injectors on the way because they are old and I don't know how dirty.
    Haven't done a maf tune and I'm running a stage 1 zzp tb. I know the lim has leaks
  13. #13 Re: Vacuum leak help
    Kemmerer, Wyoming
    I was only saying I needed a maf tune and had the wrong IFR to give background on why I was searching for ways to look for a vacuum leak. I should have said that before. I also couldn't find a vacuum leak when looking for one with starter fluid.
  1. Vacuum leak? 06 GXP
    By wikisi9 in forum General Tech Discussion
    Last Post: 06-25-2015, 07:25 AM
  2. Vacuum leak
    By Kellson in forum General Grand Prix Discussion
    Last Post: 02-28-2014, 01:28 AM
  3. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
