Thread: I over tapped the LIM, pick your poison
Results 1 to 18 of 18
  1. #1 I over tapped the LIM, pick your poison
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Plugging the coolant ports with 1/4 NPT plugs. I ran one tap too long and lost the taper so the plug won't snug up. So, the plan is to slather the threads with:
    a. Red loctite
    b. JB Weld
    c. RTV
    d. Other, please specify
    Which would you use?
  2. #2 Re: I over tapped the LIM, pick your poison
    JB Weld.
  3. #3 Re: I over tapped the LIM, pick your poison
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'd go and try and seal the threads rather than trying to get the plug in there.
  4. #4 Re: I over tapped the LIM, pick your poison
    Apr 2015
    That's what you should've done.
  5. #5 Re: I over tapped the LIM, pick your poison
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    jb weld on the threads, then run it down below the surface and fill in with rtv.
  6. #6 Re: I over tapped the LIM, pick your poison
    Dec 2008
    ****'s Creek
    JB it is, thanks guys
  7. #7 Re: I over tapped the LIM, pick your poison
    Kemmerer, Wyoming
    I did the same thing and used jb weld to fix it, it might be overkill, but I put some rtv on top when I was done
  8. #8 Re: I over tapped the LIM, pick your poison
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Suppose you could also drill/tap the next size up and plug again.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  9. #9 Re: I over tapped the LIM, pick your poison
    id go with JB weld in the threads, then run the plug into the jb weld and let it set up over night before using it, then rtv the top when the blower goes on.
    with the side cover off the lim you ca reach the bottom of the hole with a finger to smooth out/ remove any extra jb weld on the inside.
  10. #10 Re: I over tapped the LIM, pick your poison
    Dec 2008
    ****'s Creek
    Speaking of side cover, anybody use anything other than the factory paper gasket to seal that up? Nobody local has one in stock. I don't know why FelPro doesn't put one in their LIM gasket kit.
  11. #11 Re: I over tapped the LIM, pick your poison
    i dont see why you cant just rtv that cover back on. if it does leak its easy enough to add a gasket later on.
    the magnum metal lim gasket kits comes with that gasket and new injector o rings, coolant elbow o rings and t stat gasket. for 40 bucks @ rockauto for future reference
  12. #12 Re: I over tapped the LIM, pick your poison
    Dec 2008
    ****'s Creek
    Thanks, I went with FelPro and it comes with all that, everything BUT the $%^$#@ side cover gasket. Heading up to Advance, will pick up some form-a-gasket and see how it works. Still have some cleaning of the LIM to do, must have never had the PCV changed, the inside is coated with oil.
    Read an old post by Bill and also did some porting of the coolant channels at the crossover right below that cover.
  13. #13 Re: I over tapped the LIM, pick your poison
    Yup just rtv it or stop by the dealer or grab one of amazon
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  14. #14 Re: I over tapped the LIM, pick your poison
    Kemmerer, Wyoming
    Make sure you clean the old gasket of real good, when I did my lim, I didn't clean the hardened gasket of at all and it leaked real bad until I cleaned it off. If you don't have a gasket, I would make sure the rtv sets up good before adding coolant
  15. #15 Re: I over tapped the LIM, pick your poison
    Dec 2008
    ****'s Creek
    Sealed with JB weld
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  16. #16 Re: I over tapped the LIM, pick your poison
    Dec 2008
    ****'s Creek
  17. #17 Re: I over tapped the LIM, pick your poison
    I've gone just rtv plenty of times.
  18. #18 Re: I over tapped the LIM, pick your poison
    Enfield, CT
    Quote Originally Posted by Burbman View Post
    AC Delco sells just the coolant bypass gasket. Look on their site.
    Sent from my LG G3
  1. F*ck you poison oak
    By FordMan77 in forum The Rant Forum
    Last Post: 06-23-2015, 11:58 PM
  2. Zzp throttle body spacer drilled and tapped for methanol
    By 00grandprixgtp in forum For Sale - Parts
    Last Post: 03-02-2015, 08:15 PM
  3. Pick Your Poison - Coolant Color?
    By SliceTheRice in forum General Tech Discussion
    Last Post: 08-10-2010, 08:03 AM
  4. July 17 - Tinley Park, IL - Def Leppard, Poison, Cheap Trick
    By FastKatt in forum Shows and Events
    Last Post: 04-08-2009, 12:47 PM
  5. These need to be tapped?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2008, 09:29 PM
