View Poll Results: What color coolant do you run in your GP?
Voters
57. You may not vote on this poll
  • Orange (Dex-Cool)
    22 38.60%
  • Green (Standard)
    22 38.60%
  • Yellow ("Universal")
    9 15.79%
  • Other (please post alternative)
    4 7.02%
Thread: Pick Your Poison - Coolant Color?
Results 1 to 20 of 36
  1. #1 Pick Your Poison - Coolant Color?
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    I'm really curious to know what the results of this are going to be - I honestly couldn't guess who the winner will be.
    What color coolant do you run in your car?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: Pick Your Poison - Coolant Color?
    GTX Level Member cerick08GP's Avatar
    I’m running Dex (by default) because of how new my car is. I see myself going to green when my coolant is due to be changed. I’m not a Dex hater but the stuff does make a nasty mess of anything it touches. Also, I think Havoline saw them coming with this one. I’ll bet GM has lost thousands of consumers over this on going fiasco.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Pick Your Poison - Coolant Color?
    South Jordan, UT
    Wow, this is pretty close between Green vs. Dex-Cool. I have a good amount of people telling me to ditch the Dex-Cool and run green, but then I have just as many telling me to keep the Dex-Cool because green is just as corrosive.
    I know the HOAT coolant in my Jeep is supposed to be all famous for having powerful corrosion inhibitors (5yr coolant too), I've wondered if I could get away with running that stuff. The only drawback is that it's very very hard to find stuff.
    At the end of the day I just really don't know what to do. Opinions seem split (closely at least) right down the middle.
    Quote Originally Posted by cerick08GP View Post
    Explain s'il vouz plait. I'm out of the loop on that one I guess.
    Quote Originally Posted by nawarkk View Post
    I have dexcool.. I think I might change, but then again I don't know. Too many opinions.
    Amen.
  4. #4 Re: Pick Your Poison - Coolant Color?
    GTP Level Member SuperSport's Avatar
    Michigan
    Dexcool is only a problem when air is introduced into the cooling system, or when you have a LIM gasket leak, etc. Dexcool is also the cause of the plastic LIM gasket failure.
    From what I understand dexcool was reformulated a few years back (after the lawsuit) and is a different (better) animal now. So dexcool on the store shelves is the good stuff.
    Switching coolant from dexcool to conventional is difficult because if you dont get every last drop of dexcool out of your system and install the green, you can turn you cooling system into jelly.
    My vote is for dexcool, only because I am going to be running aluminum LIM gaskets.
    Edit: Damn bio you beat me by a minute.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  5. #5 Re: Pick Your Poison - Coolant Color?
    Florida
    I run the the green stuff, with a rather high concentration over winter because of the snow/ice, now it's been flushed, with a 30/70mix or so in it now.
  6. #6 Re: Pick Your Poison - Coolant Color?
    Jul 2008
    sumter,south carolina
    green... **** dexcool.
    02 GTP with mods 05 GP for DD
  7. #7 Re: Pick Your Poison - Coolant Color?
  8. #8 Re: Pick Your Poison - Coolant Color?
    West Side Michigan
  9. #9 Re: Pick Your Poison - Coolant Color?
    its also fairly hard to find non-dexcool coolant. the only reason dexcool goes bad is because there is air in the system and it starts to oxidize and gum up. make sure your coolant system is up to par and the dexcool will run just as well as the old school green.
  10. #10 Re: Pick Your Poison - Coolant Color?
    South Jordan, UT
    Good to know guys, thanks!
  11. #11 Re: Pick Your Poison - Coolant Color?
  12. #12 Re: Pick Your Poison - Coolant Color?
    South Jordan, UT
    Speaking of air in the system, can I ask you guys an almost unrelated question? I had to take my top radiator hose off last night and want to make sure I bleed out any air that might have got in there (I'm running Dex-cool). When I look at the bleeder, it's like there is a small screw inside of a bigger one! I don't know how else to explain it so I hope you know what I'm talking about. Do I open the little one to bleed or the big one?
    If everyone is clueless as to what I'm talking about, I can snap a pic if needs be.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    G-05. This is what Ford and Chrysler are using now, and it's a very good coolant. The main downside of Dex is that the corrosion inhibitors take a long time to build up a barrier on the metal, G-05 uses some silicates to fill in that gap.
    Don't be fooled by color, either. The "Yellow ("Universal")" is pretty much Dex, as is some of the "green" on the market. Look for formulations, not color. Color has become meaningless.
    Quote Originally Posted by SliceTheRice View Post
    This is G-05. It can be had at any Chrysler or Ford dealership, or Napa usually carries it made by Zerex.
    Not true. Switching from conventional to Dex-Cool, it's very important to get all of the conventional out. Going the other way doesn't matter a bit. This is why Prestone can market Dex-Cool as "Universal", because it can be used to top off a conventional system without any problems.
    The little one.
    2001 Buick Regal LS - Almost Stock
  14. #14 Re: Pick Your Poison - Coolant Color?
    South Jordan, UT
    Quote Originally Posted by Scimmia View Post
    Yeah, that's it. AutoZone and Checker don't carry it and I guess Pep Boys just stopped. I finally found a Napa that had some and I took their last case.
    The little one.
    Sweet, thanks. Any idea what size wrench opens that thing?
  15. #15 Re: Pick Your Poison - Coolant Color?
    We run Caterpillar green that used in truck engines in all of our vehicles.
  16. #16 Re: Pick Your Poison - Coolant Color?
    Apr 2009
    stockton ca
    i went green after my build ive seen a lot of nasty dexcool mess tearing into gm engines
    i triple flushed my system n went green never had issue with green
  17. #17 Re: Pick Your Poison - Coolant Color?
    Joliet, IL
    Quote Originally Posted by TorqueAutoMotiv View Post
    x2 did the same thing and its alot better IMO. no gunk anymore.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  18. #18 Re: Pick Your Poison - Coolant Color?
    SE Level Member RideMr2's Avatar
    Memphis
    Universal, Mix with all.
  19. #19 Re: Pick Your Poison - Coolant Color?
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Green stuff for me. Less crud and bull**** floating around.
    Retired
    Turbo'd
  20. #20 Re: Pick Your Poison - Coolant Color?
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    well I use Yellow now ... however when I was working for Toyota I could get Toyota Pink long life for free so my '95 I had and Blazer both ran Toyota Pink Coolant.
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  1. help me pick
    By cjim in forum Tires & Wheels
    Last Post: 05-02-2010, 12:40 PM
  2. If you could pick...
    By coreygnar in forum Off Topic Discussion
    Last Post: 04-13-2010, 09:55 PM
  3. I can Only pick one...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-11-2009, 10:19 AM
  4. July 17 - Tinley Park, IL - Def Leppard, Poison, Cheap Trick
    By FastKatt in forum Shows and Events
    Last Post: 04-08-2009, 12:47 PM
