I installed the plog / crossover, It started getting dark and a little rain started coming down. I just had enough time to clean up and put the tools away. The install went easy, I had a stubborn crossover bolt but it was no match for the Seafoam deep clean. It was one of the rear bolts, I had to work it back and forth so the seafoam could penetrate. I soaked all of the bolts yesterday and today before I started. I used grade grade 8 bolts, the header nut threads are the same as the M8 screw. Since the threads weren't damaged, there was no need to buy the fasteners (nuts). I didn't get a chance to start the car, I'll start it tomorrow to check for leaks and to hear how it sounds. Then I'll change the plugs and I won't be reusing the spark plug boot shields.
why would you not use the spark plug boot shields?
