Thread: Pulley?
Results 1 to 6 of 6
  1. #1 Pulley?
    SE Level Member RicerKiller's Avatar
    Feb 2009
    Alabama
    I was thinking of putting on aftermarket pulley after I get my exhaust done, and I was wondering if it is possible to use a puller like you would use to pull a harmonic balancer, etc. off with without damaging anything, or do you have to buy the special 150 dollar one. also how small of a pulley can you get before you need a transmission cooler or a low temp thermostat? i was thinking of going with the 3.4 or 3.2 from pfyc.
    Pulley Boys Supercharger Pulley - PFYC
    I was going to put a low temp thermostat on but I have been having problems with a po128 code, which is coolant temp below thermostat regulating temp, and I was afraid that a low temp thermostat would make it throw the same code. Is this true or not?
  2. #2 Re: Pulley?
    Barksdale AFB, LA
    If you're only getting exhaust, a 3.4 is the lowest you should be thinking of. You probably can't even run that right without knocking.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Pulley?
    I live here. UR LOSN's Avatar
    Rockford, IL
    the harmonic puller will not work, neither will a gear puller... you will end up bending the pulley rather than pulling it off.
    I would go 3.4....and scan.
  4. #4 Re: Pulley?
    Ha...don't even try to drop a pulley size with just exhaust and a t-stat...
    YOU NEED:
    180*/160* T-Stat
    CAI/HAI/FWI of some sort
    PLOG/3" Downpipe
    U-Bend Delete
    PCM (overkill, DHP, Intense...)
    Dropping a pulley size is the last thing I would do after bolt-ons...that is how I lost a motor 2 years ago...thought I had enough mods with no scanner...ended up grenading the 3rd piston...so unless a 500 motor or even more sounds good to go fast RIGHT NOW...then consider NOT swapping pullies until after you get MORE mods...
    Basically I just want to see anyone go through what I did...
  5. #5 Re: Pulley?
    Feb 2009
    Alabama
    alright thanks for the info guys ill do some more then come back to the pulley.
  6. #6 Re: Pulley?
    Your car will thank you
  1. 3.4 S/C Pulley
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 03:17 PM
