Thread: Odd voltage issues
Results 1 to 10 of 10
  1. #1 Odd voltage issues
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Base info: 1999 Buick Regal GS.
    Lately ive noticed a trend in how my car runs. On a cold start the voltage is fine(14.5 volts). However after a trip (short or long trip gives the same results) ill start the car again and my voltage stays around 11.5 volts and after about 10-15 mins of normal driving it bumps back up to normal. Any ideas guys?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Odd voltage issues
    cold start raises the rpm's making the alt spin faster raising the alt volts, warmed up at idle its lower rpm nets less volts.
    pretty common for a gm alt.
  3. #3 Re: Odd voltage issues
    Apr 2014
    South Haven, MI
    why would the voltage be so low though? Even if i get down on the car a bit to spin it faster it still takes a bit to charge back up.
  4. #4 Re: Odd voltage issues
    your battery could be on the weak side.
  5. #5 Re: Odd voltage issues
    Apr 2014
    South Haven, MI
    Yeah could be. its a 6 year old optima that was ran at 15+ volts for most of its life
  6. #6 Re: Odd voltage issues
    dirty terminals or a bad cable also come to mind.
  7. #7 Re: Odd voltage issues
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    I ended up replacing my alternator when mine started doing that stuff, likely the rectifier...running a gp alt in my bonne
  8. #8 Re: Odd voltage issues
    May 2011
    Illinois
    called the bad alternator boosted
  9. #9 Re: Odd voltage issues
    Sep 2014
    Worcester, MA
    How are you measuring voltage?
  10. #10 Re: Odd voltage issues
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    My GP will pull down to 11.5 every now and again, but not very often. Usually when letting off from light throttle, like coasting/pulling into a driveway. I can get it to do it consistently if I ever so slowly try to feather the throttle just off-idle. As I slowly press the throttle, initially I can see the rpms increase slightly (50 rpm) then back to idle (as if Im not pressing the throttle), then as I increase the throttle a little more the motor finally responds. Then as soon as I let off, it surges at 550-650rpm at 11.5 volts for 5-8 sec b4 it recovers back to 750 rpm/14+ volts.
    Its done this ever since I had the car (5yrs) and I've had 5 different alts, 2 97-98 cs130's, 1 99-03 cs130, 2 AD244's all of them did the same thing (not the reason for replacements only one alt actually died). In my case its not a rectifier or VR issue, I think its either the sensing wire, or the PCM itself. I notice if I unplug my sensing wire and plug it back in while its running, it does the same thing, it pulls the rpm and voltage way down while it tries to stabilize. All my connections are clean, 0awg big 3, battery is a 3y/o Diehard platinum with a 12.6 surface charge. Ive given up with that gremlin.
  1. Voltage issues
    By timothylockhart in forum General Grand Prix Discussion
    Last Post: 08-20-2015, 10:23 AM
  2. Moar voltage issues (I think)
    By deadwoodspecial in forum General Grand Prix Discussion
    Last Post: 12-28-2013, 09:21 AM
  3. Low Voltage
    By akarana23 in forum General Tech Discussion
    Last Post: 07-14-2013, 10:00 AM
  4. low voltage
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 10:19 PM
  5. Low Voltage
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 02-12-2011, 03:24 PM
