Thread: What is best for the first mod, 04GTP COMPG
Results 1 to 17 of 17
  1. #1 What is best for the first mod, 04GTP COMPG
    Jan 2009
    Was wondering what was the best mod to start out with for my 04 gtp-compG. I been reading alot that the 3"down pipe is a good way to start. I saw the one on ZZperformance 3" with cat and bolts on. I was wondering since I have to deal with emissions if that would cause me to fail, and when they say bolt on is it simply un-bolting stock pipe and bolting this one on?
  2. #2 Re: What is best for the first mod, 04GTP COMPG
    Charles City, IA
    Yup it just bolts in. A CAI would not be a bad first mod either. A 3" dp was my first mod.
    SMGPFC Two Nipple General
  3. #3 Re: What is best for the first mod, 04GTP COMPG
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I went in this order:
    -3" dp w/ hiflo cat zzp
    -wizair,overkill pcm, throttle body spacer, throttle body heat shield (all at the same time)
    -Autolite 605 plugs
    -ZZP Powerlog
    -3.6" smoothflow mps (this weekend)
    I had just the 3" dp on for about 2 weeks. It seemed my low end acceleration suffered a little while the midrange improved a little. It wasnt really until I got the powerlog on that everything started "working together" and i saw the biggest jump in performance. My pcm is tuned for a powerlog and 3.5/3.6 so im excited to get this 3.6 on this weekend. When i have to change plugs again this spring i will probably go with autolite 104's or the iridium equivalents.
    The downpipe cost me $35 to have a local shop install it. it took about 15 minutes if that. Make sure you get the rear 02 extension from zzp because you will need it. also your pcm has to be programmed for it so you wont throw a code. You can get an 02 bung i think but i dont know much about it so that code doesnt show up.
    Suspension mods come next. I have gmpp trailing arms already which you should get because they are only 35$ and install is very do it yourself. Will get front and rear strut braces as well as energy suspension poly mounts all around. I wish we had an upgraded front sway bar!
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  4. #4 Re: What is best for the first mod, 04GTP COMPG
    Feb 2008
    South Bend, IN
    oh and id recommend changing out the supercharger oil which is easy to do and cost $10 or so.
    also getting a fluid and filter change. if you want to mod you are going to be adding more stress to the car so you want to keep up and start preventative maint. before you do it. also switch to synthetic oil.
  5. #5 Re: What is best for the first mod, 04GTP COMPG
    Jan 2009
    I had the oil switched to synthectic a couple of months ago, I was wondering about the super charger oil and how to go about changing it. I was looking at CAI been looking at the kn, wizard and thrasher versions. What did it cost you to have your pcm programmed?
  6. #6 Re: What is best for the first mod, 04GTP COMPG
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    Quote Originally Posted by luckyjack04GTP View Post
    the s/c oil change is very easy! i just used an empty spray bottle. just take the small allen key nut off the snout. then stick the sprayer in the snout & spray the oil into the empty bottle. then fill the snout up with new s/c oil right to the threads on the snout.
  7. #7 Re: What is best for the first mod, 04GTP COMPG
    Jan 2009
    That does sound easy enough I will have to try that this weekend maybe or is it recommended to do it when the climate is warmer since I live in Wisconsin were it is freezing? Also would local parts store have that supercharger oil?
  8. #8 Re: What is best for the first mod, 04GTP COMPG
    Feb 2008
    South Bend, IN
    Heres a guide. Its for the Series 2 3.8 engine but its the same thing, same process. You can buy the oil online or get it from the dealership.
    Pontiac Grand Prix GTP Eaton M90 Supercharger Oil Change Picture Illustrated Guide
    On the intake I went with the wizair because of the insulation it, the build quality is good, its looks great and it gets great reviews. The thrasher would have been my second choice. I decided not to consider the KN because its doesnt completely seal the filter off from the engine bay and it doesn't look good in my eyes. KN is a big company and I would rather support the smaller guys who made the intake especially for this engine (Wizair, thrasher). There are also fender wall intakes which are basically just the intake tube that runs from the throttle body to the inlet hold in the side of the fender inside the engine (you probably can't see it because your stock air box is in the way). Its not hard to find people who are partial to fender wall intakes. I personally don't like them because they don't look good and the air filter will get dirty at lot faster. You can also make your own hot air intake for real cheap, fender wall intake or custom cold air intake and save money. No matter what intake system you go with the supercharger is going to be so much louder.
    For the actual air filter itself I went with an Amsoil filter. The Amsoil filters use no oil in them. Some people will say oil is ok other dont like it because the oil could potentially get sucked up and dirty up your MAF sensor. The Amsoil filters take advantage of nanofiber technology, which after some research, I was sold on. Its the same technology that the military uses for filters in their combat vehicles. The filter you would want for the wizair is the amsoil eau4090 filter. That filter would probably work on the thrasher also, you might want to check though. before the amsoil filter i did have a Spectre filter (compareable to KN filters) that I got locally and it was oiled. After replacing it with the amsoil filter I did notice a better throttle response and the supercharge whined louder. The amsoil filters are like $50 compared to the $30 Spectre.
    I got an overkill pcm. you can find him under Overkill Motorsports on the vendor section of this website. The cost of the pcm was around $250 if you keep your old pcm also, which i did or you can send him your pcm and he can program it that way and it is a little cheaper. The pcm comes from canada so it takes a week or 2 to arrive. Basically with overkill you tell him what mods you have and he "tunes" the pcm in occordance to the mods, so that makes it a little better than off then the shelf tunes. If you dont want to spend that kind of money I cant remember who else is good. Maybe someone else will chime in. I just know to stay away from ZZP's pcms because they are very hit or miss.
    I told overkill that I was going to have a pulley and powerlog but ended up putting the pcm in without the pulley and powerlog. If you do this the car will run a little rich but its not supposed to be a big deal. I just installed the powerlog finally after about 6 months of having the pcm in. wow what a difference it made.
    Some people say to change your supercharger oil every year some say 25k the manual says 50k ect ect. I'm going to do it every year because its cheap and you dont want that supercharger to break because its $$$. Better safe than sorry.
    For your trans fluid get an official gm/ac delco trans filter either from the dealership or zzp's website. They are supposed to be better than the imported ones you find at the autoparts stores. The actual filters are supposed to be thicker. Our transmissions aren't exactly the strongest componant of the car so don't mess around and get the quality stuff.
    hope this helps some more.
  9. #9 Re: What is best for the first mod, 04GTP COMPG
    Charles City, IA
    Make sure to replace the supercharger oil with the GM supercharger oil. You have to get it at the dealer.
  10. #10 Re: What is best for the first mod, 04GTP COMPG
    Donating Users blowfishRus6's Avatar
    g.a.
    deffently an intake. makes the supercharger come alive then. then exhaust mods, gotta get that hot air out.
    for those with a downpipe, does it make the car sound more meaty?? i have headers with the 3inch downpipe and with the windows rolled down it sounds more meaty. wondered if just a downpipe would do that also
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  11. #11 Re: What is best for the first mod, 04GTP COMPG
    Feb 2008
    South Bend, IN
    standing at the back of the car, slightly. besides that not for me.
  12. #12 Re: What is best for the first mod, 04GTP COMPG
    g.a.
    cool. just wondering.
    what about when your passing a row of cars at WOT?? can you hear it then. god my echos sometimes and not just the supercharger, the damn exhaust, mainly near the downpipe.
    its slow.
  13. #13 Re: What is best for the first mod, 04GTP COMPG
    Jan 2009
    Do you guys recommened the powerlog from zzp, and if so is it hard to install and does it require welding or just bolts on? Thanks to everybody and there help, so far learning alot about the car and things I can do to improve it.
  14. #14 Re: What is best for the first mod, 04GTP COMPG
    probably one of the best bang per buck mods. easy install, completely bolt on. just have to take off the stock front manifold and then put this one on.
  15. #15 Re: What is best for the first mod, 04GTP COMPG
    Feb 2008
    South Bend, IN
    blowfish,
    at WOT all i hear is pure supercharger whine. my **** is loud. at half to 75% throttle i get some engine noise in there but its not very meaty, its just engine. at WOT there is near zero engine noise. the whine got noticeably louder when i put on the amsoil air filter compared to the oiled spectre. im telling you guys that amsoil filter is the cats meow.
    luckyjack,
    If you dont go with headers the powerlog/dp combo is a must have. the front manifold is very restrictive. the powerlog completely replaces this. it was way mroe effective than i thought it was going to be. it reguires no welding. i didnt install mine but i hear its easy for some and difficult for others. if you are goign to do it yourself make sure you soak the crossover bolts with some of the rust loosening stuff because i hear those can be hard to get off sometimes. basically you have to do some exhaust work if you are going to mod your car. if you are bringing in more air (intake,pulley,rockers) you have to have a way to release it all (exhaust work). You won't need a cat-back exhaust (exhaust work from the end of the downpipe to the muffler tips) unless you are building a crazy street machine or you want to really change the exhaust tone. word of advice: these engines are hard to make sound good so don't even bother unless you have $$ to throw around and actually want to do it. our stock mufflers are supposed to be pretty decent flowing actually.
  16. #16 Re: What is best for the first mod, 04GTP COMPG
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    where can I get this power log and 3" dp? Does the dp come with the o2 sensor extention or is that another purchase?
  17. #17 Re: What is best for the first mod, 04GTP COMPG
    Charles City, IA
    ZZPerformance
    They will all have to be bought separately.
  1. 04 GTP CompG VS MKV GTI
    By GTPRiley in forum Track Sessions and Kills
    Last Post: 11-01-2008, 12:42 PM
  2. Modified CompG Side Decal
    By 04CompG in forum Off Topic Discussion
    Last Post: 10-06-2008, 09:19 AM
  3. 04 CompG endlink size
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 07-08-2008, 08:15 PM
  4. My 2004 GTP CompG - 56k get a sandwich
    By stkks in forum Visual/Body Modifications
    Last Post: 05-13-2008, 07:48 AM
  5. My CompG
    By RKELC in forum Visual/Body Modifications
    Last Post: 04-29-2008, 06:57 PM
