Thread: North Star tb and maf . Idle issues.
Results 1 to 4 of 4
  1. #1 North Star tb and maf . Idle issues.
    SE Level Member gbgn1's Avatar
    Dec 2012
    TX
    I've got a n* throttle body and maf on my car. I maf tuned it and it runs great. Problem is if I rev the car say 3000 rpms . When the rpms come down usually its unstable . And sometimes it just kills the motor. Is this a known problem? Should o go with a 5.3 cable throttle body? And maf?
    Thanks!!
  2. #2 Re: North Star tb and maf . Idle issues.
    Kemmerer, Wyoming
    I would double check the security of the throttle cable in the throttle body and make sure it is pulled all the way to the end of the channel. your idle sounds like it's either a throttle position sensor issue, or the maf is defective.
  3. #3 Re: North Star tb and maf . Idle issues.
    Dec 2012
    TX
    I've tried multiple tps , with always the same result. The tb isn't hanging up in anyway. Haven't tried a different maf but the car runs great . Just the issue under hard throttle.
  4. #4 Re: North Star tb and maf . Idle issues.
    Kemmerer, Wyoming
    can you swap the original throttle body back on and see if the problem goes away? I would do that before I went and bought a new maf.
    it could be a vacuum leak, how do your fuel trims look?
  1. FS: North Star TB/plate
    By buck531 in forum For Sale - Parts
    Last Post: 12-04-2014, 12:00 AM
  2. intercooler, 42 lb injectors, and north star tb installed and having issues.
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2014, 10:08 PM
  3. How and what is needed to add a North star to a gen 3 l67
    By thunder71173 in forum General Tech Discussion
    Last Post: 05-21-2011, 02:35 PM
  4. ported north star casing
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 03-08-2011, 10:46 AM
  5. North Star parts
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2011, 01:07 AM
