Thread: Supercharger pulley came off
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 Supercharger pulley came off
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    98gtp was driving yesterday gave it some, gas next thing I know I hear a few clunks n lost boost n most of power...look under hood the supercharger pulley is gone, and only the shaft appears to be fine.. anyone ever had the pulley come off the shaft...it was a rebuilt snout with a3.4 pulley all bought from zzp and they pressed the pulley on the snout last year..
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Supercharger pulley came off
    being ive used a sc pulley puller, id say thats almost impossible. id be calling zzp and asking them wtf?
    pics of the carnage? you find the pulley?
  3. #3 Re: Supercharger pulley came off
    Buffalo
    Damn. Thats a first
  4. #4 Re: Supercharger pulley came off
    Topeka, ks
    No couldn't find pulley...I press hub and bearings daily at work press on **** shouldn't just come off a year later
  5. #5 Re: Supercharger pulley came off
    Topeka, ks
  6. #6 Re: Supercharger pulley came off
    Topeka, ks
    Mind blowing wtf would cause that it's been a year almost exactly now..it spins freely n when I give the car a lil gas it spins...it was noisy as hell tho..car is nice n quite now. Could I need new rotor needle bearings? When I spin the shaft it feels smooth n play at all..n it had new coupler Could the needle bearings be the reason it was so noisy?? Are they hard to replace
  7. #7 Re: Supercharger pulley came off
    look under the engine a top the splash shield for the pulley, near the motor mount. if its not down there look again back where it popped off. it maybe cracked. the outer bolt is also gone.
  8. #8 Re: Supercharger pulley came off
    Topeka, ks
    Outer bolt??
  9. #9 Re: Supercharger pulley came off
    Topeka, ks
    I just gonna get a modular set up 3.4, but what about this bolt missing send me a pic what it should look like and installed if possible
  10. #10 Re: Supercharger pulley came off
    yeah, the bolt on the shaft.
  11. #11 Re: Supercharger pulley came off
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Should be a vented bolt just like the one on the end on this snout
  12. #12 Re: Supercharger pulley came off
    Topeka, ks
    Mine's always just had a ****in plastic cap in it lol wtf zzp
  13. #13 Re: Supercharger pulley came off
    Topeka, ks
    So what about the needle bearings can they cause it to be noisy are they easy to replace?
  14. #14 Re: Supercharger pulley came off
    Topeka, ks
    Anyone got an extra bolt for the snout
  15. #15 Re: Supercharger pulley came off
    St. Louis
    Quote Originally Posted by xxburkettxx07 View Post
    the needle bearings can make noise but most of the time you will get resistants in the rotors when spinning, to replace you have to take off the front drive pull the rotors, tap and insert grease fitting so you can press out the old bearings, although at this point I would be interested to see if you have any play in the rotors and how the inside of the case looks
    I think I have one laying around
  16. #16 Re: Supercharger pulley came off
    if the sc is making sounds now, its broken. either the coupler or bearings. bearings are not so easy to just change.
    hand turn the sc see if you hear any thing.
    most wont have a extra bolt. jy time or dealership.
  17. #17 Re: Supercharger pulley came off
    Topeka, ks
    Last year when I installed the
    supercharger the coating was all good still
  18. #18 Re: Supercharger pulley came off
    post a vid of the sounds its making now.
  19. #19 Re: Supercharger pulley came off
    Topeka, ks
    It don't make any sounds right now it's dead silent lol jk but when I spin it by hand no resistance it spins as it should n extra play or anything
  20. #20 Re: Supercharger pulley came off
    Topeka, ks
    No extra play**
  1. Pulley Boys Supercharger Pulley 3.4
    By ngj123 in forum For Sale - Parts
    Last Post: 09-09-2013, 11:45 PM
