Thread: Coolant issue, thinking head gaskets...
Results 21 to 40 of 41
  1. #21 Re: Coolant issue, thinking head gaskets...
    you can check the lim tq, id not take em out and re do em tho. whats the point?
    if the sc gasket is wet again, ( high on the suspect list) you know thats the issue. make sure the lim and blower are both 100% free of any old gasket too. if any old crap has been left on thats a possible leak for sure.
  2. #22 Re: Coolant issue, thinking head gaskets...
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Got off work a little early to start this process over the weekend and got busy...
    It doesn't look as bad as I had expected under there...
    Although, the gasket "came right off" with the blower and appears wet again...
    Am I missing something during install?
    Should I leave it a truly "dry" install this time as to "tacking" the gasket with spray gasket?
    I picked up another gasket just to do it that way instead of the other RTV method...
    Also, in this pic, it appears the gasket didn't "seal" / like the sc didn't "squish" it when bolted down? (Around the port the spray gasket is still there)
    Also, the area again around the PCV appears to be un-sealed and oily --
    Almost looks like a drip in this pic, under the TB opening
    Feedback from the pros is always appreciated!
  3. #23 Re: Coolant issue, thinking head gaskets...
    is that sc gasket wet? its got two colors to it now.
  4. #24 Re: Coolant issue, thinking head gaskets...
    I never use spray gasket or rtv, just slap a felpro gasket on dry.
  5. #25 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    Thanks for the speedy replies...
    Yes, the gasket is oily-wet...Doesn't seem to be coolant?
    Looks like PCV might be the source of oil?
    Thanks again
  6. #26 Re: Coolant issue, thinking head gaskets...
    it maybe worth checking the pcv valve out, its under that oval cap a top the blower.
  7. #27 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    Sorry for the double post...
    Going for a dry install...
    Here goes nothin...
    Happy new year all...
    Edit -- PCV looks good...
    If you look at this exploded view --
    http://www.wholesalegmpartsonline.co...ssembly=383614
    You see the o-ring is above the lip of the PCV and under the spring...
    Is this the correct way to install?
    Should the o-ring be under the PCV lip?
    Mine is currently *under* the PCV lip...so sandwiched between the PCV and sc instead of between the PCV and spring...
  8. #28 Re: Coolant issue, thinking head gaskets...
    its like dark here im like how the f is it so lit up out side in these pics. then i look and see CA lol
    oh, clean that tb better, that whole brass plate on the back side. push it open clean the sides of the flap and the walls of the tb good where it sits in the closed position.
  9. #29 Re: Coolant issue, thinking head gaskets...
    Looks clean enough.
  10. #30 Re: Coolant issue, thinking head gaskets...
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    id be closing off those coolant ports in the lim.
  11. #31 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    As always, thanks for the replies...
    Quote Originally Posted by ScottyDoggs View Post
    Yea, I was losing sunlight quick yesterday after my post, so I decided not to rush the re-install and waited to finish it off today...
    I may just pick up a new PCV for peace of mind and some more throttle body spray to clean it up more...
    Quote Originally Posted by JamesIvey24 View Post
    I am interested in this "mod", although I live in SMOG crazy CA and I am unsure if this will affect my ability to pass SMOG...
    Also, if I did decide to do this mod, it is easier done with the LIM off, correct?
    I have to dremel down the side port (under the EGR tube) and I dont think this can happen with the LIM attached plus the shavings need to be cleaned out and would be easier with it off...
    Also, this go round didn't look like coolant but more like oil although this thread is about my coolant issue....
    I'll get it all back together and pressure up the cooling system and see what happens...
    Thanks again all...
  12. #32 Re: Coolant issue, thinking head gaskets...
    has nothing to do with the egr.
    probably best to take it off dont want metal shavings inside the engine. heres the how to. http://www.grandprixforums.net/threa...w-to-Mod-a-LIM
  13. #33 Re: Coolant issue, thinking head gaskets...
    Quote Originally Posted by GoldGTP View Post
    Thanks again all...
    To add to what Scott said, this mod won't effect your emissions testing.
  14. #34 Re: Coolant issue, thinking head gaskets...
    Buffalo
    You could always trade the orange gasket with right stuff rtv. I guarantee you that won't leak.
  15. #35 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    Just a quick update --
    I got a wild hair today and decided to pull the water pump and swap in a new one...
    Also went through the extra effort of finding the "stamped" metal/rubber gasket...
    Even though my coolant elbows are fairly new, I thought since I was pulling the water pump, might as well get some new elbows as well...
    On a good note, I found that the PCV valve for some reason had 2 o-rings in the PCV "chamber"...I looked and inspected for some time before I noticed the 2nd o-ring in there...
    It was causing the lip of the PCV valve to be above the bottom of the side-draft opening for the air flow...
    I sketched up something in paint of what I noticed--
    Hopefully finding this issue resolves the oiliness under the blower...
    Also, after everything was back together, I tried to pressurize the cooling system again and started spraying fittings with soap water...
    I found the heater core hose adapters o-rings were shot and being Chevy is closed today, I picked up 2 of these --
    http://www.amazon.com/Dorman-47027-H.../dp/B00G3YU0ZW
    The price for the o-ring from the dealer is 14.00 and local price for new fitting was 16.00 so in essence I paid for having them now...
    It's getting late here so I have to plan on putting a bow on it tomorrow...
    Thanks again for following along...
  16. #36 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    Well, got it all back together and pressurizing the system shows it holds ~15 PSI...
    I thought about leaving the tool hooked up over night, although I decided to finish off the work...
    I am still seeing temps rise and fall, although I don't remember where the temps actually like to be...(I have a few other cars and don't generally drive the GTP much or the wife is driving it)
    In my other car, the temp gauge usually rides in one spot for the duration of the trip...
    Does the GTP like to fluctuate?
    It seems when I stop in traffic is when I see temps rise, when I'm moving I see them fall...
    Although, I have yet to see it rise above ~212-213 via OBD scan tool...
  17. #37 Re: Coolant issue, thinking head gaskets...
    if you sit and idle the temps will rise to 210 easy, (your fans dont turn on till 212) then drop when your moving. pretty normal.
    check your rad coolant level over the next few mornings, keep the over flow filled to its line too. it will self bleed over time if you left any air in there.
  18. #38 Re: Coolant issue, thinking head gaskets...
    Sacramento, CA
    Thanks for all the replies ScottyDoggs, much appreciated!
  19. #39 Re: Coolant issue, thinking head gaskets...
    Feb 2016
    Taunton, Ma
    I have same issue with my GTP. With 140K miles I plan on doing the LIM gaskets, and while I'm at replace the S/C bearings. My question now being that I don't plan an intercooler but would there be any benifits to the S/C phenolic spacers that are available?
  20. #40 Re: Coolant issue, thinking head gaskets...
    The spacer would do you no good and the supercharger bearing aren't super problem prone, if it's not making noise or being a issue I'd leave them. But if you got a press and know what you are doing, then I guess you could take the snout apart and do it.
  1. Thinking about replacing the upper and lower intake manifold gaskets?
    By tom5170 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2015, 04:28 PM
  2. WTB: ARP Head Studs & Head Gaskets, FelPro or Multi Layer
    By JordanGT in forum Wanted To Buy - Parts
    Last Post: 03-05-2015, 12:51 AM
  3. Which head gaskets?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2012, 07:12 PM
  4. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  5. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
