Thread: Abbott Racing heads
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 Abbott Racing heads
    SE Level Member Blacknitews6's Avatar
    May 2017
    south jersey
    I'm interested in Abbott S1 heads since i only want a mild port job.
    Has anyone use them. I appreciate any help. Thanks.
  2. #2 Re: Abbott Racing heads
    diy port job then. run ya 100 bucks in tools.
  3. #3 Re: Abbott Racing heads
    May 2017
    south jersey
    i hear ya. But i have no experience porting heads. If i go to far
    them i'll heads to find replacement heads. But i always wanted to try ported.
    I helped on my 241 LS1 back in 2002. that was pretty cool. I know if you touch the right spot you can
    pick up great gains without removing that much material. Thanks for your advice.
  4. #4 Re: Abbott Racing heads
    i never did it before either but it all turned out well. even if you just polished them its an improvement.
    i took out a couple mm all around.
    our crappy stock exhaust castings.
    and ported, not even polished yet.
  5. #5 Re: Abbott Racing heads
    Kemmerer, Wyoming
    easiest place to start on a hand port is to grab a used set of lower intake manifold gaskets and just gasket match all the inlets on the heads. I don't have the time or interest to try porting my own, but if I did, I would get a nice set of tools and make sure I had no doubt in my mind exactly what I was going to do before I did it, and the theory behind what was being done.
  6. #6 Re: Abbott Racing heads
    Antioch, IL
    Dont be afriad to DIY port! scotty made me do my heads.
    20160801_164307 by Corey S, on Flickr
    20160831_173532 by Corey S, on Flickr
    before and after exhaust port
    20160728_174100 by Corey S, on Flickr
    20170223_122744 by Corey S, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Abbott Racing heads
    May 2017
    south jersey
    Man you guys do great work!! Since i did some work on my LS1 heads it might be worth giving it a try.
    I'm interested in doing some work in the valve guide area and just blend everything so there's a smooth
    transition in the bowl and throat, then remove casting flash. Thanks guys for the pics. I appreciate it.
  8. #8 Re: Abbott Racing heads
    May 2017
    south jersey
    Quote Originally Posted by SgtMarshal View Post
    I know what you mean. I don't have the skill to try to port my heads. And if you add my time trying to port the heads without
    screwing them up, plus buying the tools to do the job it will cost close to Abbott's S1 heads. Plus they do more than cleaning up the
    casting flash. They do a valve job, they install 130# spring and retainers, they mill the heads, replace seals.
    So doing my own heads would never compare to the work they do. And for their $800 it would cost me more than that in parts and tools.
    And they are pro's. I could never do what they do with all the work they do.
  9. #9 Re: Abbott Racing heads
    Donating Users
    Kansas City
    Quote Originally Posted by Blacknitews6 View Post
    These are a lot more forgiving than aluminum LS heads, too. Gotta keep that in mind as well. Usually makes life easier with iron.
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  10. #10 Re: Abbott Racing heads
    May 2008
    Schuyler, NE
    I don't know anyone that had run Abbott heads. But for $800, you can bet that it isn't much of a port job. But porting and polishing your own heads is expensive and time consuming. And it makes a huge mess.
    You need a pretty big air compressor, preferably one that runs on 220v. Then a die grinder...in my experience, the cheap ones work like crap compared to the ones that cost closer to $100. Then all the sanding drums, polished, etc.
    Last set of heads I did, I stuck I think around ten or fifteen hours into each head. Next time, I just spent money on vendor heads. If you watch the classifieds, you can usually find good deals on zzp s3 or s4 heads.
  11. #11 Re: Abbott Racing heads
    i was up to the 18-20 hrs per head, but i did it over time. a few hours each day, its nothing you want to sit down and do for 8 hours straight.
    and for sure your not gonna do any huge damage from a run away bit or nothing. worst thing you could do is nail the valve seat where the valves seat up. thats a sketchy area in the bowl. after you do a few bowls, your like ok, here we go again lol
  12. #12 Re: Abbott Racing heads
    Antioch, IL
    Harbor freight die grinder, I used autobodynow ebay burrs and trickflow sandpaper. $100ish in tools and alittle bit of my time.
    20160726_225553 by Corey S, on Flickr
    20160801_165651 by Corey S, on Flickr
    Its all easy to do
    20170223_113842 by Corey S, on Flickr
    20170223_121750 by Corey S, on Flickr
    **** I even polished my valves
    20160821_180704 by Corey S, on Flickr
    20160902_152021 by Corey S, on Flickr
    20160902_162014 by Corey S, on Flickr20160902_161944 by Corey S, on Flickr
    So save some money, enjoy some experience and gain power because your not gonna gain 50hp vs diy porting vs any vendor.
  13. #13 Re: Abbott Racing heads
    May 2017
    south jersey
    That second photo looks like a pro did that not some average guy in his garage with a dremel.
    The other pics look more like what you would see a novice do.
  14. #14 Re: Abbott Racing heads
    May 2017
    south jersey
    Quote Originally Posted by ItHurtz View Post
    The second photo doesn't look like a novice in his garage using a dremel. Looks like a shop did that.
  15. #15 Re: Abbott Racing heads
    May 2017
    south jersey
    GTPpower....Who's heads do you recommend? Cause Turbo Tim just told me to just change the springs/retainers since i'm
    not going to the track too often. I just want a quick street car. That shows how honest ZZP is. Cause Tim
    could have BS me into getting CNC heads. I know i don't need to remove the heads to change springs, but
    if i was going to Abbott does a lot for the money and back up their work. Most shops might charge $750 or more for reconditioned
    heads. Plus i only want a mild port job since it's not a race car and i'm only running a ZZP ST2 cam.
    Sure i can leave the heads on the car/ no porting and just replace springs and throw in the ST2 and be done with it. Which i might do since mild ported
    heads won't add all that much. But i thought i might look into a mild port job as well.
  16. #16 Re: Abbott Racing heads
    Antioch, IL
    a novice lol. only after pic is the exhaust with flash which shows every mark known to man. I assure you they look better than the pics posted.
    exhaust porting has more gains than intake.
  17. #17 Re: Abbott Racing heads
    May 2008
    Schuyler, NE
    Zzp heads are about the only ones I can recommend anymore. But on a turbo car, it's pretty much a waste of money. There are much cheaper and easier ways to gain power. I would just install a set of 130# springs and it'll make more power than you know what to do with.
  18. #18 Re: Abbott Racing heads
    May 2017
    south jersey
    Haha...i believe it. Cause i'm not looking to squeeze every HP since i only want a strong street car. I figure with the parts
    i'm gonna run the car might hit mid 12's, which would be great.
    Here's the list of parts i plan to run:
    ZZP Z7 PT6262 kit w/intercooler at 14 psi.
    ZZP ST2 Cam w/130# spring and retainers
    Either a aluminum intake or ZZP's L36 conversion intake
    Ported TB
    3 inch downpipe
    3 inch catback
    Vigilante 2800 stall
    Retuned PCM
    I'm sure there will be other little things as the big continues. And i appreciate any input you guys
    might have. I'm new to this FWD stuff..lol. And i thank all you guys that posted in this thread.
  19. #19 Re: Abbott Racing heads
    May 2008
    Schuyler, NE
    Yeah, I wouldn't even mess with the heads if you want to run 12's. That 6262 has the ability to get you into the tens.
    You should get a double roller timing set. And a set of slicks for the track if you don't have them already.
  20. #20 Re: Abbott Racing heads
    May 2017
    south jersey
    Thanks i appreciate your help. If i want to shoot for low 12's or 11.9 with drag radials what other mods would you recommend? I know my tranny won't like it too much, but i plan later on to have TEP mod my trans. I would like to touch 11.90's truely.
    I just noticed on your mods that you are on a stock trans. That's great cause other than test and tune at Atco Raceway my car won't see a lot of track time, just for tuning purposes mostly. Man i appreciated your advice. You already saved me money by not having my heads ported. I can use that $800 to buy a Vig.2800. Or other things like the timing set. Thanks man for all your help.
  1. Replies: 16
    Last Post: 01-28-2016, 10:09 AM
  2. L67 cylinder heads & L36 heads
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 11-26-2015, 08:56 PM
  3. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  4. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  5. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
