Thread: 2005 Grand Prix GTP Hard Starting
Results 1 to 4 of 4
  1. #1 2005 Grand Prix GTP Hard Starting
    SE Level Member juggernaut56's Avatar
    Dec 2008
    Winnipeg, MB
    Once it got cold out my GP became hard to start...it will struggle for about 5 seconds in the morning, sputter like its going to start and die out. Sometimes I need to try 3 times. After the initial hard start it is just fine for the rest of the day. I have recently cleaned the throttle body and replaced the spark plugs and wires so those can't be blamed...I checked the fuel pressure and with 0 pressure in the line it jumps to about 60 psi as soon as the key goes on, and seems to stay at 60psi while idleing. I noticed occasionally the needle was bouncing very rapidly between 55-60psi. Is this too high? Does the car even have a fuel pressure regulator?
    Thanks
    2005 Grand Prix GTP - Since September 2015
    2005 Grand Prix GTP CompG - Sold in 2011
    1996 Bonneville SSEi - Sold in 2009
    1989 Bonneville SSE - Junked in 2006
  2. #2 Re: 2005 Grand Prix GTP Hard Starting
    I was going to say to remove the throttle body completely and clean it but you have done the cleaning already.
  3. #3 Re: 2005 Grand Prix GTP Hard Starting
    GT Level Member penright's Avatar
    Mar 2013
    United States
    My 06 3.8 N/A has the same issue. I notice it more when remote starting in the morning, one shot if it does not hit, then out in the cold and scraping ice.
    My brother-in-law and I was discussing and we thought the pressure was leaking down over night. To test the theory the last two mornings I cycled the key on/off/on/off. Then hit the remote start and both morning it fired without issue. I will continue the next few morning to see if it was just luck these two days or a real pattern.
    Quote Originally Posted by juggernaut56 View Post
    I checked the fuel pressure and with 0 pressure in the line it jumps to about 60 psi as soon as the key goes on, and seems to stay at 60psi while idling.
    Is it zero because you bled the line before hooking up the tester? I am curious if you hooked the tester up at the end of the day, then started the car, shut it off, what does the pressure show overnight?
    Watching Car Tech, they trouble shot a fuel system that was leaking down. Basicly they suggested isolating (close) the fuel feed to eliminate the fuel pump check valve. Then isolate the return to eliminate the regulator. Then isolate both to eliminate a leaking injector.
    Talking to a GM guy, I asked what fails more often, he said pull the vacuum hose on the regulator (off the top of his head) and see if it is wet. So this morning I pop the hood and could not find the regulator, did some googling and it looks like on 04+ the regulator is built into the pump. I still need to do more searching to verify 100%, unless someone here can answer that.
    I am starting a thread to discuss brands/kits of "Gas Fuel Injector Tester". Once I do I will come back and edit this post with it's link for future searchers.
    Which tester are you using and where did you get it?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  4. #4 Re: 2005 Grand Prix GTP Hard Starting
    GXP Level Member
    Mar 2015
    Tomball
    It should stay at 65psi all the time weather idling, driving or WOT.
    Jeff
  1. 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the cause
    By racer81x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-08-2015, 09:44 PM
  2. Hard Starting 92 Grand Prix 3.1
    By verlando in forum General Grand Prix Discussion
    Last Post: 11-03-2012, 10:25 PM
  3. testing fuel pressure on 04 grand prix and hard starting when hot
    By skinner in forum General Tech Discussion
    Last Post: 10-25-2012, 08:37 PM
  4. 2005 Grand Prix Hard Shift
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2011, 03:36 PM
  5. 2007 Grand Prix Starting Hard
    By packerfanjc in forum General Tech Discussion
    Last Post: 06-13-2011, 10:22 PM
