Thread: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the cause
Results 1 to 11 of 11
  1. #1 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the cause
    Dec 2013
    IOWA
    I bought a 2000 3800 GP a week ago from a guy who took it away from his daughter. Has 177K on it and bought it for $375, It started right up and drove on the trailer. He had cut the Cat off it for Scrap, so when I got it home I put a piece of pipe on it and unplugged the 02 sensor that goes behind the cat. It ran and drove good for several days and put about 40 miles on it with no problems, until yesterday.
    I filled the car full of gas and it started to rain out and I drove it 7 or 8 blocks in the rain and started running ruff/cutting out and died, it would refire but acted like it was flooding itself out when I would push on the gas and would run briefly and die. I let it sit a day, started it up and it idled fine for a couple minutes, but when I put it in gear it would die/ cut out, same as when I pushed on the throttle.
    Could this be a bad Throttle position sensor?
    Or is it caused by not having the cat and the sensor unplugged? I had a 96 3100 GP that I cut the cat off and replaced with a pipe and unhooked the 02 sensor and drove it 4 years without a problem, I also had a couple 97-2001 GTP's that I cut the cats and exhaust off and raced on dirt and never had a problem.
    Or could it be something else?
  2. #2 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Plugs, wires, fuel and air filter.
    You could have just left the rear o2 plugged in, its not going to hurt anything and its going to throw a code being unplugged anyway, I doubt that has anything to do with your issue.
  3. #3 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Dec 2013
    IOWA
    Quote Originally Posted by Slick2500 View Post
    Thanks for the info, those are on my list to change, hell it might be a plugged fuel filter, I just didn't know if it could be the TPS sensor or not.
    The guy cut the pipe to close to the back sensor for me to get a pipe hooked up to it no problem so I had to cut it off and unplug the sensor.
  4. #4 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Dec 2013
    IOWA
    I had another TPS sensor laying around from a car that ran fine 2 years ago, I installed it, and it starts fine the first time and idles fine, but the second you touch the throttle it cuts out and dies. I had it sitting there idleing for 3 minutes it idles fine and all of a sudden it started running rough and died.
    I also noticed that before I filled it with gas the heads up display worked fine and registerd fine, now since I filled it full, it reads 0 for all the fuel range and the average economy, it does register that I have used 0.3 gallons since filling up.
    I plan on putting a new fuel filter on it tomorrow when the parts store is open, maybe it's plugged? It looks like it's been on there awhile
    Any other thoughts on what it could be? I wouldn't think the crank sensor since it does start, but could it be? I don't know **** about any of this new electronic fuel injected stuff.
  5. #5 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Donating Users Uno99's Avatar
    Appleton, Wi
    Could be the rich or lean fuel trim issue so.e GP'S get when you delete the cat and rear bank o2. Any access to a scanner? Any code.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  6. #6 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Quote Originally Posted by Uno99 View Post
    thats the 01 up cars.
  7. #7 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Appleton, Wi
    ^^^ His post count trumps mine. He knows I'm still learning :-)
  8. #8 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    theres a 20 page thread on the 01 up rear o2 sensor and deleting it. or not. seems your best to run a cat and o2. thats 01 up crap tho) hes got a 2000.
  9. #9 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Jun 2013
    Indiana
    Have you cleaned the TB??
  10. #10 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    Dec 2013
    IOWA
    Sorry guys been busy with work and haven't had time to give a update.
    I changed spark plugs first, and that didn't change anything, so next I had a friend stop over with a scanner hooked it up and it had 6 or 7 codes in it, I cleared the codes, and it started right up and ran normal with no problems.
    Since then, I drove it about 80 miles with no issues, other than the service light coming on which I figured it would due to not having a cat or rear o2 sensor. I hooked the scan tool back up after 80 miles and it had 3 codes:
    P0108: MAP Or BARO Pressure Signal High
    P1106: MAP Sensor Circut Intermittent High
    P1811: Maximum Adapt & Long Shift
    I presume those first 2 codes mean that I need to replace the MAP sensor? Would the Map sensor cause the problem that I had? I have driven the car about 400 miles now with no issues runs fine.
  11. #11 Re: 2000 Grand Prix Hard starting and dying/Cutting out when on throttle, whats the c
    check the wires to the plug for the map. if they look good swap a new one in there.
    the 1811 a shift kit should bandaid for ya.
  1. 2000 Grand Prix GT cutting out
    By coolhand in forum General Grand Prix Discussion
    Last Post: 06-09-2014, 11:52 AM
  2. Hard Starting 92 Grand Prix 3.1
    By verlando in forum General Grand Prix Discussion
    Last Post: 11-03-2012, 10:25 PM
  3. testing fuel pressure on 04 grand prix and hard starting when hot
    By skinner in forum General Tech Discussion
    Last Post: 10-25-2012, 08:37 PM
  4. 2000 Grand Prix GT not starting.
    By Grim844 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2012, 03:17 PM
  5. 2007 Grand Prix Starting Hard
    By packerfanjc in forum General Tech Discussion
    Last Post: 06-13-2011, 10:22 PM
