Thread: SSIC vs S2IC ZZP recommendations
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
  1. #41 Re: SSIC vs S2IC ZZP recommendations
    AN lines are a whole different animal. theres a few ways t make line connections with them. nothing is cheap either.
    but a compression fitting is a compression fitting no matter how you slice it.
  2. #42 Re: SSIC vs S2IC ZZP recommendations
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    https://www.youtube.com/watch?v=puIoAa5RRBs
    is this what you're talking a boot? my skylark's fuel lines are like the ones in this video. but i also know carburetors dont run near as high of a pressure.
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  3. #43 Re: SSIC vs S2IC ZZP recommendations
    thats one style, heres their web site, lots of fittings and connectors to be had. http://www.anplumbing.com/
  4. #44 Re: SSIC vs S2IC ZZP recommendations
    Sep 2015
    gulf breeze, fl
    stupid question, is it called a compression fitting because of the inner piece mashing the braided hose against the outer piece when it threads in?
    do these generally offer greater protection against leaks?
  5. #45 Re: SSIC vs S2IC ZZP recommendations
    compression fittings are used on hard lines, AN has one thats a compression fitting on one side to fix to a hard line and threaded to take a hose on the other.
    you could also use a double flair tool and unions in place of the compression fittings.
  1. Top Swap and S2IC Knock KR issues
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 01:43 PM
  2. S2IC hood clearance ...Cradle spacer...WTF!?
    By rell2005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2012, 08:40 AM
  3. S2IC Question...Cradle Spacer WTF!?
    By rell2005 in forum General Tech Discussion
    Last Post: 03-11-2012, 03:18 AM
