I have my SSIC for sale (complete with core, pump, lines, rad, hardware and injector spacers) if anyone is interested. It's listed on wbody marketplace facebook page. /shameless plug
I'm waiting to see what zzp puts up for sale on their BF weekend thing, I guess at a minimum I'll hope to at least get some of the kit for whichever core I go with, I just hate that I'm probably going to need spacers if I go with a full size, which is most likely what I'll end up doing.
I was referring to the cradle spacers.
Does pre 04 have less space between the hood and SC? I placed a 3.5" block in my SC and closed the hood and barely touched the liner in one corner.
Jeff
I wasn't really worried about the TB, I'll either turn it or make a turn down (well down and forward).
Jeff
So... apparently ZZP's modified fuel rails are out of stock for the l67 (only shows if in cart), and I'm not willing to fork over $400 for their billet logs (tbh im not really happy about the price of the modified fuel rails for the l67)....
I've done some searching and keep reading referencing about some method of modifying them that isn't exactly beautiful, but works, and doesnt involve some expensive aftermarket FPR?
Oh, and just to be clear, WBodystore and PRJ no longer offer them.
Out of curiosity, why does ZZP put an aftermarket FPR in their L67 kits?
@ scotty, does it leak at all?
zzp doesn't actually use an aftermarket fpr in their modded fuel rails, but in their billet fuel logs they do, because you can't really use an oem fpr on them. you might be able to use an oem fpr on the billet logs if you can attach the housing to the rails.
wont lie, they all leaked a tiny bit. once the line near th ealt was massaged into place to clear the alt better i made them all tight one more time while under pressure till they stopped leaking. one put up a fight. but i got it sealed off.
truth is im still checking them after every first start in the morning. been days now, bone dry.
Any reason you didnt use braided lines
money. i looked up "AN" lines and fittings and all that crap. this was the cheapest way to do it. using a flair tool cant cost much or any more tho.
should you build a set like this, you install the rail first, then drop the core and blower on. only draw back is ill have to take the lines off to get the rail off with the blower still on. lines are trapped under the snout and tb.
nvm, apparently i dont know what a compression fitting is, lulz i just thought any AN fitting was the same thing
