Thread: Lame dyno results.
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Lame dyno results.
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    Finally got my mods in signature installed and got tuned and dyno'd results were 229whp and 253wtq. While I wasn't expecting huge numbers these just seem low for a rocker/header/pulley setup. My tuner did say I was maxing injectors so that and a IC are gonna be the next step.
    Dyno was done on a dynojet if that matters.
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: Lame dyno results.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Factor in drive line loss you are looking at 275 hp and 305 tq. Far from terrible.
  3. #3 Re: Lame dyno results.
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Actually that is a little sad. What pulley size? Rockers alone should get you close to that.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: Lame dyno results.
    Mar 2015
    Appleton, WI
    Quote Originally Posted by chrsmi1 View Post
    Running the 3.5, I have a 3.4 but kept running out of injector and getting a few blips of KR so went back to the 3.5" . . . AFR was a solid 11 until 5600-6100 rpm where injectors were causing a issue.
  5. #5 Re: Lame dyno results.
    Yeah that is considering the l32 is ~200whp stock.
  6. #6 Re: Lame dyno results.
    Jul 2012
    Chicago
    Is that not a little bit on the richer side?
    -Carl
  7. #7 Re: Lame dyno results.
    gardner,mass
    No way your maxing injectors
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  8. #8 Re: Lame dyno results.
    Kemmerer, Wyoming
    Shouldn't be maxing injectors on a 3.5. Do you have a vacuum leak or an exhaust leak? If it was me, I would use that hp tuner and check injector duty cycle yourself. Wouldn't be the first time a dyno operator didn't know what was going on. 11 to 11.5 is where you want the afr
  9. #9 Re: Lame dyno results.
    Mar 2015
    Appleton, WI
    Quote Originally Posted by SgtMarshal View Post
    He said my injector cycle was at 98% but I will confirm that with my HPTuners version . And if I would have been in the 240/270 range, no, this post wouldn't exsist. I suppose my goal for the post was to see if there is anything I'm missing that could explain the lower than expected numbers. Leaning it out to 11.5 might be an option .
  10. #10 Re: Lame dyno results.
    Sep 2015
    flint
    Quote Originally Posted by kewGTP View Post
    Hptuners calculation (specifically the pulse width part) is wrong for all 04+ grand prix. It reads roughly 15% too high. I havent figured out the correct formula for it yet mostly because the information for it is not availible.
    Doesnt run 9s
  11. #11 Re: Lame dyno results.
    Jan 2013
    Raleigh, NC
    The main thing to remember is that every dyno is different. You could go 10 minutes up the road and get 5 or 10% more. The real question is, would you have made this post is you got 240/270?
  12. #12 Re: Lame dyno results.
    Step 1 find a different "tuner" if he said those injectors are maxed LOL!
  13. #13 Re: Lame dyno results.
    Is there any knock across the rev range?
    I couldn't imagine maxing out those injectors...
    I was able to run a 3.1" pulley on stock injectors on a 97-03 car. Virtually the same AFR.
    I'd have someone else look at it.
  14. #14 Re: Lame dyno results.
    Mar 2015
    Appleton, WI
    Knock free with the 3.5 , was seeing 1-3* with the 3.4 at 5200rpm and above. I'm gonna play with the tune when I have some free time next week
  15. #15 Re: Lame dyno results.
    How's timing?
  16. #16 Re: Lame dyno results.
    Mar 2015
    Appleton, WI
    11-12* across the range
  17. #17 Re: Lame dyno results.
    Yea you need to increase that timing
    04 Comp G.
  18. #18 Re: Lame dyno results.
    Jan 2013
    Raleigh, NC
    Buy a 3.6 and see about throwing that on there with like 17 or 18 degrees WOT.
  19. #19 Re: Lame dyno results.
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    11-12* timing? Lol what.
    That needs to be increased to 16+
    I never drop below stock timing (16). If I see KR at that number, it's time to pulley up.
    And maxing out your injectors has to be false too. Look at my setup in my sig. I have all that on stock injectors running a 11.2 AFR. Yes they are at full duty cycle, but if my injectors can hold their own on my setup, yours should easily.
  20. #20 Re: Lame dyno results.
    Mar 2015
    Appleton, WI
    Looks like I'm just gonna start my tune from scratch like I should have done originally.
  1. dyno results
    By ADrugDealer in forum General Grand Prix Discussion
    Last Post: 08-17-2013, 08:14 PM
  2. Dyno results - 98 GTP
    By iree75 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2013, 09:01 PM
  3. Dyno Results
    By SnowFlake in forum General Tech Discussion
    Last Post: 02-18-2012, 10:47 AM
  4. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
