Thread: Help!!! Loss of boost psi
Results 1 to 12 of 12
  1. #1 Help!!! Loss of boost psi
    SE Level Member 40thAnnGTP2002's Avatar
    May 2015
    high point nc
    I have a 2002 Grand Prix GTP and I have the following :
    Speed daddy headers
    Magnaflow 3" high flow cat converter
    Lucas 42.5 lb injectors
    Zzp 1.0 PCM
    Autolite 104s
    Ac delco wires
    Drilled t-stat
    Bypassed the boost solenoid completely so its off car
    All the vacuum lines are brand new
    Checked sc gasket and intake gasket
    Checked bypass valve and even replaced it
    Check map sensor even replaced it
    My issue is I'm only getting 4psi boost max on my scanner and aftermarket gauge. Idk what to look at next. I've tried everything... Any suggestions???
  2. #2 Re: Help!!! Loss of boost psi
    if you just did all those mods and still have a stock pulley on the sc, that could be normal. your boost drops when you install headers. i went from 7 psi to 5 psi after header install.
  3. #3 Re: Help!!! Loss of boost psi
    May 2015
    high point nc
    Thank u for the info also I got the pcm retuned after I added injectors and I have a 3.4 press on pulley and I told him to go ahead and figure that in the tune but I still haven't done it bc I can't find anyone around here to do it and I don't have the tool to. I did score a gen v swap with everything and it has a MPs already installed so that will give me something to do haha
  4. #4 Re: Help!!! Loss of boost psi
    3.4 on a gen 5 maybe pushing it, but it may work out, all cars are different and take mods how ever they take em. you'll just have to scan it for kr and see.
  5. #5 Re: Help!!! Loss of boost psi
    May 2015
    high point nc
    No I'm not putting the 3.4 on the gen v lol the gen v has a mps on it. It comes with 3.2 and 2.8 but those are way too much so imma get a 3.5 and run it.
  6. #6 Re: Help!!! Loss of boost psi
    solid plan.
  7. #7 Re: Help!!! Loss of boost psi
    Feb 2013
    Missouri
    3.5 will still be too small for those mods. You might be able to get away with a 3.6 if you are lucky. Why are you running larger injectors? Is your tune set up for it?
  8. #8 Re: Help!!! Loss of boost psi
    says zzp 1.0 pcm, so i guess its tuned for it.
  9. #9 Re: Help!!! Loss of boost psi
    Feb 2013
    Missouri
    If he told ZZP to tune for it. I'm curious why he wasted his money on it, didn't gain him anything. I can barely run a 3.6 on my Gen V with SSAC, ERs (with L76s), a Reptile tune, and an FWI. I still randomly get blips of KR.
  10. #10 Re: Help!!! Loss of boost psi
    once you own a tuner you can fix that......in car tune is still best.
  11. #11 Re: Help!!! Loss of boost psi
    Feb 2013
    Missouri
    I'm sure it will, lol. Money is on the way for it.
  12. #12 Re: Help!!! Loss of boost psi
    May 2015
    high point nc
    I don't have the gen v setup on yet and yes its tuned for the bigger injectors or I'd be running rich lol
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Loss of boost after plug wires change?
    By Bluemagic in forum General Tech Discussion
    Last Post: 05-30-2012, 11:20 AM
  5. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
