Thread: Basic Hop-Up
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 109
  1. #1 Basic Hop-Up
    Nov 2015
    California
    Hi, I just got my first supercharged 03 Grand Prix. Im looking to do the intake, exhaust, and a smaller supercharger pulley. Im on a teenager budget unfortunately. So not the top of the line equipment, but no garbage. Basically I want a sleeper, but something with a throaty intake and supercharger whine. The exhaust I plan on putting a remote controlled butterfly in it, that way I can have it stock and practical or obnoxious and frowned upon "HA-HA" Can someone point me in the right direction for an intake? Then the smaller pulley, whats the trouble with a knock sensor or something? Is it better to go with one of the smallest available or something more mid range? As far as the exhaust I can figure that out, input is appreciated though. Thanks for the help!
  2. #2 Re: Basic Hop-Up
    Kemmerer, Wyoming
    don't mess with the knock sensor, there are no issues with them. there is a whole guide on doing what you want to do. we get this question almost on a daily basis.
    http://www.grandprixforums.net/threa...00-Powered-Car!!
  3. #3 Re: Basic Hop-Up
    knock aka KR is read off the knock sensors, you dont change them, you need to tune the kr out if possible.
    your first mod is headers, theres goes 240 out of the budget asap.
  4. #4 Re: Basic Hop-Up
    Nov 2015
    California
    I figured it was pretty common, just didn't know exactly where to look. So say I installed a Thrasher press on 3.25" pully, what do I do to tune the knock retard down? What if I Install the 3.0" pulley, beside more power are there any differences, again how do I tune the knock retard down? Are the modular pulleys better? I will most likely fab up my own intake, and what brand of headers should I get? The smog laws in CA are kinda strict, so I believe they need to be CARB legal. I know this is all newbie stuff, but that's exactly what I am at this point.
  5. #5 Re: Basic Hop-Up
    you need to do much reading. start with that link marshal posted.
    your not running anything smaller then a 3.4 without a ic or running e85 fuel. and it needs a tune.
    speed daddy headers are the cheapest you'll find @ 200 shipped, you need to up grade to band clamps. 4 of em at 10 a pop.
  6. #6 Re: Basic Hop-Up
    Nov 2015
    California
    I've done a little reading. So if I get an intake, 3.4" pulley, and speed daddy headers would I need to do anything about tuning? Oh and what size clamps for the exhaust? Will this get rid of the U bend everyone talks bad about?
  7. #7 Re: Basic Hop-Up
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    Yes the headers will eliminate that horrible ubend...also you will need to get an upgraded flex section due to the one that comes with the speed daddy's is crap...be sure to use the stock manifold gaskets and not the ones that come in the kit due to them being garbage as well (or get new at the parts store)your choice of course!....zzp sells the upgraded flex for around 25-32 dollars shipped i believe....you will also need an extension harness for the o2 sensor,also sold by zzp and others.
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  8. #8 Re: Basic Hop-Up
    Apr 2011
    MICHIGAN
    The clamps are if i remember correctly (2) 2.5 and (2) 3".
  9. #9 Re: Basic Hop-Up
    I do not believe SD's are carb compliant. I could be wrong though.
  10. #10 Re: Basic Hop-Up
    Quote Originally Posted by Slick2500 View Post
    They are not.
    Take it from me teenager man.
    Don't blow all your money at once, and research. Don't think because you took a few minutes to read some articles you've got it down pat. From the questions you're still asking, it shows you need to still get some things understood. I typed that thread for a reason years ago...it might be a little out dated but the basics of it are there.
    If it were me, and I was on a budget...
    I'd get a Tuned PCM, 180* T-Stat, a 3" Catted downpipe, and toss a cone filter on the TB. That'd probably set you back $300~ or so, if you do the work yourself.
    Leave the pulley alone.
    Enjoy it for awhile.
    Then figure out what you want from the car, and go from there.
  11. #11 Re: Basic Hop-Up
    Nov 2015
    California
    I actually had a big BBK paper filter laying around. Rigged it up, and Im happy with it. Total investment - $0. I think I'm going to hold off on the headers, the car is plenty fast enough for me in stock trim. Too fast and I'll get in more trouble, I just barely ducked under a felony reckless evasion charge on my streetbike lol. I'll probably get the t-stat, PCM, and do some exhaust work. I'll remove the resonator and mufflers and just put a glass pack where the resonator normally sits. Then add in some pipe where the mufflers used to be, keeping the stock exhaust tips.
  12. #12 Re: Basic Hop-Up
    hangover park IL
    the early TOGs are the only CARB exempted headers, good luck finding the original CARB sticker, though it may be available from the other guys
    ~James~ Psychotic Gearhead
  13. #13 Re: Basic Hop-Up
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Just cut the manifolds up and route them out the fenders.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  14. #14 Re: Basic Hop-Up
    hangover park IL
    that's really the only logical choice if removing mufflers
  15. #15 Re: Basic Hop-Up
    Nov 2015
    California
    Can I flip then upside down and cut some holes in the hood? That's obviously the best way to keep the bottom of the car cool
  16. #16 Re: Basic Hop-Up
    Quote Originally Posted by WhenInDoubtThrottleOut View Post
    Just quit it.
    Leave the entire stock catback.
    It's not restrictive at all and the 3800 sounds like dog ass.
    Yes
  17. #17 Re: Basic Hop-Up
    Nov 2015
    California
    I've educated myself a little bit.
    180 T-stat
    NGK TR55 plugs
    3800 Performance V1.0 PCM
    ZZP 3" or 2.5" catted down pipe
    Cone filter
    Thrasher 3.4" pulley
    Smaller supercharger belt
    So as far as the PCM goes, I'll still pass smog right? Will the S/C pulley make a difference as far as smog? CA smog is really strict, I wonder if I'll even get by with the aftermarket catalytic converter. If not I can always swap it. Now if I go with the 3" down pipe, will it still bolt up to the stock resonator, or should I get a 2.5"? I'm not getting a cat back exhaust those are too expensive, so the down pipe needs to bolt to stock. I'll be getting these things in steps, should I do the downpipe or the PCM first? Because the PCM is tuned to operate with exhaust work, should I get the down pipe first? Thanks for all the help
  18. #18 Re: Basic Hop-Up
    being your in ca, you need tog, or slp headers, or you will not pass that lame inspection you have there. your cat must be carb compliant too. zzp cats are not.
    the pcm will pass tho. its the visual part you fail.
  19. #19 Re: Basic Hop-Up
    Nov 2015
    California
    Installed some NGK TR55 plugs today, as well as a 160° thermostat. Pretty quick and painless. Sold a motorcycle today for a little pocket change. I bought it for $350, put $200 in it, a couple weekends worth of work, and sold it for $1700. Had to pay off the last bit of this car, leaving me with a few Benjamins for parts. PCM or down pipe?
  20. #20 Re: Basic Hop-Up
    take the 160 out, thats to cold, your engine wants to run at 200 degrees.
  1. basic radiator fan ??
    By weissmertz in forum General Tech Discussion
    Last Post: 05-28-2015, 10:18 PM
  2. Basic Mod Question
    By KIRALY in forum General Tech Discussion
    Last Post: 09-06-2012, 04:19 PM
  3. Basic ?? 3.4
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2012, 08:25 AM
  4. Why your basic car will never handle...
    Last Post: 01-28-2011, 03:13 AM
  5. Basic audio Qs
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2008, 12:27 PM
