Thread: Basic Hop-Up
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 109
  1. #21 Re: Basic Hop-Up
    Nov 2015
    California
    My apologies I actually put a 180° in it.
  2. #22 Re: Basic Hop-Up
    Nov 2015
    California
    Im about to order a 3 inch "offroad" zzperformance down pipe. Their cats are not carb legal, so I'm not going to take a chance on wasting the extra $70 for a cat that can prove itself useless. When I smog it I will just swap the downpipe back to stock for the day. Downpipe and gaskets are going to run me $180. After that I'll be getting the PCM, and a 3.4" pulley for the S/C. Im going to stick with a black Thrasher press on pulley, I want everything to appear stock so the smog visual doesn't give me trouble. I'd love to do headers, but smog legal headers are kind pricey. I imagine the bolts on the down pipe are baked with dirt, maybe a little rust. Should I hit them with some WD-40 throughout the week letting them soak?
  3. #23 Re: Basic Hop-Up
    Nov 2015
    California
    Found this (http://r.ebay.com/tnz3wT) on ebay by Speed Daddy. It comes with hardware and everything. It's quite a bit cheaper so I'm a little skeptical, but it fits quite nice in the high-school budget. How bad can it possibly be? My fab skills are pretty good, so I can do some custom work if necessary. If I find some good feedback on it, I'll buy it tonight.
  4. #24 Basic Hop-Up
    Many of us run there headers. Not sure on there downpipe but it should fit. For $200-220 why not just get headers instead?
    04 Comp G.
  5. #25 Re: Basic Hop-Up
    Nov 2015
    California
    They will not pass CA smog visual. The down pipe I don't mind swapping every 2 years, but headers are a little excessive. Headers that will pass are around $500 I believe, not worth it unless I run into a bunch of extra money.
  6. #26 Re: Basic Hop-Up
    Ahhh didn't see that you were in Cali. Yea downpipe would be easier to install/uninstall.
    04 Comp G.
  7. #27 Re: Basic Hop-Up
    Nov 2015
    California
    Downpipe is ordered. I'll probably take my stock one off ahead of time, I know I'll probably be excited to put the new down pipe on as soon as it comes in. I went ahead and ordered the speed daddy down pipe, I'll leave some feedback on that for others.
  8. #28 Re: Basic Hop-Up
    Nov 2015
    California
    Downpipe took me 30 min or so to take off, from jacking up the car to lowering it back down. I sprayed the bolts a few hours ahead of time, and used a breaker bar, U-joint, and extensions. Definitely an easy job as long as you make sure you're completely on the nuts before you start wrenching.
  9. #29 Re: Basic Hop-Up
    Nov 2015
    California
    Had no issues with the Speed Daddy downpipe. Gaskets it came with were great as well. Seems to me with the intake and exhaust it pulls harder.
  10. #30 Re: Basic Hop-Up
    Downpipes free up a few extra horsepower.
  11. #31 Re: Basic Hop-Up
    Nov 2015
    California
    Just ordered an Overkill Motorsports PCM. $255 including shipping, had them take the codes off for a 180 t-stat and high flow/no cat. Im keeping the stock PCM for smog purposes, I have a feeling when they plug into the OBDll something will come up.
    Speaking of smog. If I put the stock intake, exhaust, and PCM back in, but left a 3.4 pulley in it would knock pretty bad wouldn't it? Even if I kept it out of the boost area, would it even run all the monitors in order to pass smog?
  12. #32 Re: Basic Hop-Up
    the tuned pcm will be fine. all systems will show ready. see no reason why it wont pass smog.
    when you swap the dp for inspection just dont beat on it, normal driving should not make KR.
  13. #33 Re: Basic Hop-Up
    Nov 2015
    California
    Oh well thats good, I might still keep it just in case. It's only $70 anyways. I developed a sticky lifter, any remedies for clearing that up?
  14. #34 Re: Basic Hop-Up
    You sure it's a lifter though??
    I can almost bet it's the cheap ass china built single walled flex pipe on that downpipe. They always tick and make noise.
    But if you still thinks it's valvetrain, dump a half quart of trans fluid in the oil to clean the engine. Trans fluid is like the laundry soap for motors, it cleans everything.
  15. #35 Re: Basic Hop-Up
    Nov 2015
    California
    Yeah im positive it's a lifter. I changed the oil and substituted 3/4 a quart for marvel mystery oil. Hopefully I can get it cleaned up, the exhaust is pretty solid it doesn't leak. Sold my Ford Exploder today, so I ended up buying an Aeroforce Interceptor reader, 3.4 pulley, pulley puller, and a smaller belt. The PCM should be shipped out Monday, probably took Thanksgiving and today off. Thought I would be low on cash being a teenager and all, but things are coming together fairly quick!
  16. #36 Re: Basic Hop-Up
    Nov 2015
    California
    So after all of this, what kind of numbers am I looking at for power? I was thinking around 280hp and 300+ foot pounds of torque. Is that reasonable?
  17. #37 Re: Basic Hop-Up
    Quote Originally Posted by WhenInDoubtThrottleOut View Post
    lmao...no
  18. #38 Re: Basic Hop-Up
    Nov 2013
    Wisconsin!
    Maybe 230ish max to the wheels.
  19. #39 Re: Basic Hop-Up
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    chp MAYBE but not whp,
    you smog test will be fine, I have SD headers with their 3'' downpipe and no cat and my smog papers shows all ready.
    I also think its the SD flex pipe making that ticking noise
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  20. #40 Re: Basic Hop-Up
    St Thomas Ontario
    Quote Originally Posted by koRnhead View Post
    30whp from a downpipe and a tune? doubt it
  1. basic radiator fan ??
    By weissmertz in forum General Tech Discussion
    Last Post: 05-28-2015, 10:18 PM
  2. Basic Mod Question
    By KIRALY in forum General Tech Discussion
    Last Post: 09-06-2012, 04:19 PM
  3. Basic ?? 3.4
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2012, 08:25 AM
  4. Why your basic car will never handle...
    Last Post: 01-28-2011, 03:13 AM
  5. Basic audio Qs
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2008, 12:27 PM
