Thread: What can I get by with?
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 What can I get by with?
    Oct 2015
    Kansas
    I've got a 99 Buick Park Avenue Ultra. This is for a junkyard war competition where I have to make 8 1/4 mile passes. We are on a dirt cheap budget. $500 and the car was 350. I'm not afraid to go over a bit. But I've been doing alot of reading but I want to know what can I get by with? I'm not worried about reliabilty. How small of pulley can I get by with? Can run 100 octane fuel or higher if need to help with KR. Plan is to put it on a diet and pulley swap and intake. Maybe exhaust and hope for the best. Any advise? Thanks
  2. #2 Re: What can I get by with?
    Slam some 116 race gas in the tank and put a 3.4 on it with nothing else and let it eat.
    It really wont be much faster though, car is still heavy.
  3. #3 Re: What can I get by with?
    hangover park IL
    hack off exhaust at the downpipe. cut the car down to a shell
    ~James~ Psychotic Gearhead
  4. #4 Re: What can I get by with?
    Yeah.. each seat is likely at least 80-100lbs. I'm basing that off a Bonneville seat being 80 and the PA being larger.
  5. #5 Re: What can I get by with?
    hangover park IL
    ditch the giant underseat battery for a smaller one, add a junk jumper cable wire for an additional batt negative to block ground path
  6. #6 Re: What can I get by with?
    GXP Level Member
    Mar 2015
    Tomball
    So between 97 and 99 they put the battery under the seat?
  7. #7 Re: What can I get by with?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Pull all the insulation, pull the alternator off (if your battery will last the runs) Gut Everything not related to moving the car. dash, seats carpet, soundproofing, trunk lid, hood body panels mirrors, as long as its still solid. Do minimum fuel for runs,
    if you see KR, Drill the Tstat, colder the engine less KR (for a little while)
    If your hacking it up, don't Buy an intake, make one, if there is no hood, aim an open pipe somewhere cool (since only a few runs who cares about filter.)
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  8. #8 Re: What can I get by with?
    Quote Originally Posted by Turbocharged400sbc View Post
    This
    Quote Originally Posted by 04lss View Post
    I really hope this is ****ing serious.
    Please be serious.
  9. #9 Re: What can I get by with?
    Oct 2015
    Kansas
    Yeah, we are planning to gut it completely and hack the exhaust as well. Also planned on building an intake. My team and I have been around racing, just unfamiliar with the 3800. Was more looking on little tricks to do and how small of pulley I can get by with for this application. I've read on forums alot but reliability is a factor in most advise and I don't care about that.
  10. #10 Re: What can I get by with?
    hangover park IL
    keep the plumbing to the rear air shocks but ditch the ride leveling pump or make it so that you can hook it up with jumper cables to add air... and be a stand-alone compressor for your tires even.
    pumping up as high as you can to keep it so that the car only dips an inch off of full rise when someone sits on the trunk lid.
  11. #11 Re: What can I get by with?
    hangover park IL
    find two late model Cadillac spare tire donuts that are the spun aluminum rims in 16 by 4 for out back
  12. #12 Re: What can I get by with?
    hangover park IL
    add lead pellets to the front lower cross tube of the engine cradle
  13. #13 Re: What can I get by with?
    Kemmerer, Wyoming
    if you can find a dhp tuner, you should turn off the evap codes, egr codes, random misfire, and might as well remove the egr valve and evap solenoid. the 16" torque star aluminium wheels are the lightest, I think.
    if you put too small of a pulley on, the car will see the predetonation and cut timing, which won't make the car faster. but since reliability doesn't matter, just disconnect the knock sensors, it might be able to survive the 8 runs or whatever
  14. #14 Re: What can I get by with?
    hangover park IL
    put the smaller Grand Prix or Grand Am brakes on the front and borrow a Mustang rear set of rims and drag slicks for the front just use half inch spacers and hack the fenders to clear
  15. #15 Re: What can I get by with?
    hangover park IL
    if you can't get lead pellets to fill the front crossmember start taking off hood prop rods from older cars and shove them through
  16. #16 Re: What can I get by with?
    hangover park IL
    any weight forward and below axle center line on the front is good, anything above and behind is the worst
  17. #17 Re: What can I get by with?
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    Build some zoomies out the hood, itll sound fantastic
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  18. #18 Re: What can I get by with?
    May 2008
    Schuyler, NE
    Can you use nitrous? That thing would boogie if you can find a cheap kit.
  19. #19 Re: What can I get by with?
    Oct 2015
    Kansas
    We are allowed to use Nitrous, since we are supercharged. We are put in the anything goes class. We were considering Nitrous. We are gonna rig up a methanol injection to try to combat temps and hopefully get some extra hp. Gutted it yesterday and lost about 300#. Planning to get a pulley this week. Still trying to get it to idle. It'll start up and run for a few minutes then just buck and die. starts right back up though. When trying to launch it bucks but once you get it over like 2000 rpm it is good. I don't have to get it fixed but gonna try cleaning the MAF today and see if it helps.
    Also what about the bypass for the supercharger? Do I need to do something with it?
  20. #20 Re: What can I get by with?
    GXP Level Member
    Mar 2015
    Tomball
    Well you don't need it, so lock it closed. How about an extra light motorcycle battery, might still have to have a jump box, but it would cut about another 60#'s out.
    Jeff
