Thread: New injectors... 60's or 80's?
Results 1 to 16 of 16
  1. #1 New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Is it possible to have too big of an injector?
    I'm looking to upgrade injectors soon. 60's will probably handle any setup I put together, but... Is there any good reason not to go for the 80's? There is a minimal price difference, and for that little extra cost, I would be guaranteed to never outgrow them. Plus, I can only imagine they would fetch a higher price when I eventually de-mod.
    Current setup:
    42.5lb injectors
    E82
    3.0" Pulley (looking to go sub 3")
  2. #2 Re: New injectors... 60's or 80's?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I think a lot of people that run a 2.55-2.8 Gen v FSIC setups are fine on 60s. Id imagine youd need 80s with a turbo setup running high(ish) boost.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Quote Originally Posted by BoostedPontiac View Post
    E85 or gas?
  4. #4 Re: New injectors... 60's or 80's?
    Kemmerer, Wyoming
    You need 80s on e85
  5. #5 Re: New injectors... 60's or 80's?
    hangover park IL
    80's
    we're at the limits of ours with e85 at our next pulls with the TR
    I have 60's in my turbo wagn and wish I had went with 80's
    we got the riv to run on 160's
    ~James~ Psychotic Gearhead
  6. #6 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    So it sounds like I'll be needing the 80's.
    I'm still curious about having a larger injector than needed. Hypothetically, would you see any driveability issues if you ran 80's on a stock setup with gas? (Assuming you adjusted the tables in the tune for the proper injector size.)
  7. #7 Re: New injectors... 60's or 80's?
    May 2008
    Schuyler, NE
    With an m90, you probably wouldn't ever need 80's, unless you do a big cam and ic.
    Idle might be a little bit rougher with 80's, but not much.
  8. #8 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Which is an eventual possibility for me. The reason I ask is because for the extra $30 up front, it would be nice to not have to worry about injectors if/when I get to that point.
    I can deal with that. You're saying the pulse width can go short enough that it won't go rich at idle?
    Sorry if this is a dumb question. I've just never seen it discussed before. Like with a carburetor, you want to make sure you have the proper size because they have very defined limits, but does the same apply with injectors?
  9. #9 Re: New injectors... 60's or 80's?
    May 2008
    Schuyler, NE
    It probably will run somewhat rich at idle. You may notice more misfires, but it's not going to be a huge difference.
  10. #10 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Can anyone else confirm this? Has anyone experienced this first hand?
  11. #11 Re: New injectors... 60's or 80's?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    I ran #60s on my old xp build e85, is2 heads etc dyno'd 356whp...
  12. #12 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Quote Originally Posted by danomite02 View Post
    Do you recall what your max injector duty cycle was?
  13. #13 Re: New injectors... 60's or 80's?
    I break stuff selliott's Avatar
    Kansas City
    I run 80s in the turbo car
  14. #14 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    Quote Originally Posted by selliott View Post
    E85 or gas? Any driveability issues? Does it maintain stoic at idle?
  15. #15 Re: New injectors... 60's or 80's?
    Kansas City
    E85 and no drivability issues, related to injectors anyways. Im also running a walbro 400. Reptile has done all the adjustments to my tune.
  16. #16 Re: New injectors... 60's or 80's?
    Mar 2014
    Tucson
    This has me leaning toward the 80's. Although our top end fueling requirements would be different, idle conditions should be the same, and that's where my concern is.
    Thanks for the feedback.
  1. Injectors
    By rryanwswan69 in forum Wanted To Buy - Parts
    Last Post: 01-10-2014, 02:04 PM
  2. l67 injectors and tb on l36
    By l67ss in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2013, 09:30 AM
  3. Injectors
    By jdwyat in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 01:00 PM
