Thread: Broke my oil pressure sending unit
Results 1 to 7 of 7
  1. #1 Broke my oil pressure sending unit
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. I just finally got my car up and running after a couple months. But in the process I managed to break the 2 studs off of my oil pressure sending unit. Does anyone know where to buy another one of these? Hopefully a auto parts store will carry it. If so does anyone know the size of the threads?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: Broke my oil pressure sending unit
    Orland Park, IL
    Will this work?
  3. #3 Re: Broke my oil pressure sending unit
    What two studs?
    The terminal ends?
    Because the sensor itself just screw into the side of the oil filter adapter/block. And technically you don't even need it, they are known to fail and piss oil out and they only alarm you when the motor has 5 psi or less of oil pressure and by that time it's already toast.
  4. #4 Re: Broke my oil pressure sending unit
    Feb 2013
    37.295091, -121.930053
    couldnt you set it to be higher while its getting a tune?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Broke my oil pressure sending unit
    Orland Park, IL
    I have a oil pressure gauge.. Sorry I should of mentioned that.
  6. #6 Re: Broke my oil pressure sending unit
    google the brand oil pressure gauge you have for its sending unit.
  7. #7 Re: Broke my oil pressure sending unit
    Orland Park, IL
    Thanks. Worked like a charm
  1. oil pressure sending unit?
    By beaver75 in forum General Tech Discussion
    Last Post: 03-29-2011, 10:04 PM
  2. 1985 oil pressure sending unit
    By Cyll in forum General Tech Discussion
    Last Post: 06-13-2010, 12:01 PM
