Thread: Is there a way to tell what's causing kr?
Results 1 to 16 of 16
  1. #1 Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Is there a way to tell what's causing kr? I think I have enough supporting mods to run a 3.6 pulley but can't even run a 3.8 without kr. Kr usually starts at 3000 rpm gets up to 2.5-3* and will drop to nothing then start again at 4700 and will go up to 5* I let off bf it goes up anymore.
    I have an 04 gtp 103 plugs gapped at .50, 180 thermostat, fwi, walbro fuel pump, new fuel filter, yt 1.84 rockers, zzp 3" down pipe w/o cat, front plog, and an intense can tune.
    Does this sound like a tune issue? Or is there something else I could try to see what's going on?
  2. #2 Re: Is there a way to tell what's causing kr?
    im willing to bet its due to the canned tune. in car tune is so much better.
  3. #3 Re: Is there a way to tell what's causing kr?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    103's imho are too cold for the mods listed.
  4. #4 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    He tuned it in car sort of...he drove it up and down the street wide open, and it just barely got a blip of kr. All I had then was a hot air intake, and a stock exhaust without a cat. Now I've done all this to it and I'm getting kr.
    What happens if your plugs are too cold? Just poor gas milage or can it cause kr?
  5. #5 Re: Is there a way to tell what's causing kr?
    not sure if the plug can cause kr. 104's gapped at 0.50 work good.
    but with your smaller pulley now i bet you need lower timing. as it was tuned for a stock car.
  6. #6 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    I put the 3.8 back on to be safe...I thought...ans still get the same amount. I have an areoforce, how much it too much timing advance?
    I'll call intense in the morning and talk to them about it.
  7. #7 Re: Is there a way to tell what's causing kr?
    theres no rule really, just averages. its what the car will take. every car is a little bit different.
  8. #8 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Gotcha. . I really appreciate the help. I've read for hours and couldn't come up with anything.
  9. #9 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Took a short video of my kr and long term today... can anyone give me a place to start looking? I'll appreciate any advice. Thanks!!
    https://youtu.be/RgJXs6tlLUs
  10. #10 Re: Is there a way to tell what's causing kr?
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    Throw some race gas in it to see if its false. If it is itll stay, if not get headers, then a real tune.
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  11. #11 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Sounds like a good idea. I'll pick some up tomorrow.
  12. #12 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Could it be valve float?
  13. #13 Re: Is there a way to tell what's causing kr?
    Mar 2015
    Port Huron, MI
    Maybe, not sure on the 1.84's but on my 1.9 modded rockers I had a FWI, headers, and the 1.9's and had 8-9* KR Before we started tuning at the top of 2nd gear, he got it down to 2-3 KR, claiming it was valve float, could be a possibility
  14. #14 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    Thanks, I'll try the race fuel, that'll tell the tale.
  15. #15 Re: Is there a way to tell what's causing kr?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    what causes KR? too much boost, not enough fuel, too much timing, too much load.
    what else are you scanning in conjunction with KR to see the whole picture? What is your B1S1 doing during this time? what is LTFT locking in at? what's the commanded timing look like? How's the MAF frequency and MAP values when you see KR? you need to review the whole picture and correlate the operating conditions.
    The intense canned tune (way back in the day), they were notorious for bumping the timing way up and not keeping up the fueling. But that was 10 years ago, I'm sure things are different now.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  16. #16 Re: Is there a way to tell what's causing kr?
    Oct 2015
    Ironton, oh
    I called and talked to them earlier, he told me to check for vacum leaks and that if my long term was 0 or less I'm getting enough fuel and something else was causing it.
    What values should I be looking for with the maf frequency and the map values?
  1. 4* of KR what do you think is causing it??
    By JcGTP39 in forum General Tech Discussion
    Last Post: 03-21-2012, 09:29 PM
  2. What is causing this?
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 01:30 PM
  3. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
