Thread: 2002 GTP Stalled at Cold Start; Now Won't Start at All
Results 1 to 10 of 10
  1. #1 2002 GTP Stalled at Cold Start; Now Won't Start at All
    Oct 2014
    Dayton, Ohio
    Hello all,
    I had an issue start recently where my car would stall on a cold start, but would fire right back up. If I gave it gas when it'd start to stall, it'd continue on fine. Once 30 seconds - a minute had passed and the engine was a bit warm, it ran with no issues, and if I started the car while still warm, no issues.
    Yesterday I hopped in my car to go to the gym. The car did not continue on fine once I got down the road, and now it will barely stay on for a second if it even starts at all. I replaced the IAC and that did not help, and my EGR is deleted. I'm just wondering what else could be causing this issue? Thanks in advance,
    Nick
    But they did it on the fast and the furious! So I did it twice. That makes me twice as fast right?
  2. #2 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    unplgu the maf and try
  3. #3 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    St. Louis
    Either that or try bending the tab 85 out on the fuel pump relay. Maybe the low speed setting is going.
  4. #4 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    Oct 2014
    Dayton, Ohio
    No dice on both of those =/.
  5. #5 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    test for fuel and spark. fuel test right after it stalls out. see if you got pressure in the rail.
  6. #6 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    Oct 2014
    Dayton, Ohio
    Quote Originally Posted by ScottyDoggs View Post
    Will do that, but I do believe the engine is getting spark because when I put my foot on the gas, it'll keep the car from just a bit longer. Seems to be more of a fuel issue. Never know, though.
  7. #7 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    Oct 2014
    Dayton, Ohio
    Car has spark and pressure at the rail
  8. #8 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    GT Level Member mguzzo's Avatar
    Buffalo NY
    change fuel filter, pressure does not guarantee flow.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    May try to replace your crank position sensor
    Team JB-Weld
  10. #10 Re: 2002 GTP Stalled at Cold Start; Now Won't Start at All
    Buffalo NY
    ^^ if you have spark the crank sensor is fine.
    i just went thru this a month ago. fuel pump was dying, couldn't provide flow.
    if it turns out to be the fuel pump, get an OEM / Delphi pump. Under no circumstances get an Airtex pump -- i had two out of the box failures with the Airtex pumps
  1. Cold Start Stalling
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 05-20-2014, 10:25 PM
  2. Engine Stalled And Now Will Not Start...
    By deltatango in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2013, 06:54 AM
  3. 2000 GTP Stalled and Won't Start
    By patori in forum General Tech Discussion
    Last Post: 01-21-2013, 05:18 AM
  4. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
  5. 98 gtp 3.8L sc...stalled wont start...
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 05:52 AM
