Thread: If you had $500 What mod would you do?
Results 1 to 16 of 16
  1. #1 If you had $500 What mod would you do?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So I got some cash from the insurance for my minor bumper damage. half is going in the bank the rest is play money.
    Im trying to figure out the most effective/power per $ way to build more power.
    Right now the engine is apart, down to the block, so install time isn't an issue. I have headers, an open cone, and a MPS. I do not have a tuner system yet, and im on the stock trans. it is not my DD, but I do want to be able to use as a backup car.
    I have four thoughts,
    1. Light cam,
    2. tuner and 80# injectors for e85 conversion
    3. wait and see if WBS or ZZP have a black Friday sale on an intercooler.
    4. rockers
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: If you had $500 What mod would you do?
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    Intercool would be a good option, lets you pulley down safely and wont kill milage or drivability like a cam. E85 would kill milage also and 80# injectors are overkill. I would personally say though save it and put it towards tuition, im in the same pickle lol
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  3. #3 Re: If you had $500 What mod would you do?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by keatonregal View Post
    I don't want to go all out (for now), just something to get it firmly away from the stock GTP. Id love to have over 300 Crank hp
  4. #4 Re: If you had $500 What mod would you do?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    a tuner, shift kit and nitrous, 75 wet shot...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  5. #5 Re: If you had $500 What mod would you do?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by NebTurboST5 View Post
    Nos isnt really legal here, (yeah I know most of the mods violate some emission law or another)
    But NOS on a street car is a big No No from what ive heard
  6. #6 Re: If you had $500 What mod would you do?
    Quote Originally Posted by 04lss View Post
    With that being said, I would do a cam, new timing chain, springs, retainers, and ls7 lifters. If you shop around you should be able to find all of that for under $500
  7. #7 Re: If you had $500 What mod would you do?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by Slick2500 View Post
    I have a set of LS7 left over from my monte, id just have to have them cleaned/checked by a machine shop. (bunch of metal was in that engine.
    I have a rollmaster chain sitting on the shelf to put on.
    no tuner though
  8. #8 Re: If you had $500 What mod would you do?
    1. Light cam,
    4. rockers
    1. You can get a cam for pretty cheep used.
    2. 45# or 60# injectors would be better - but wont increase hp at all
    3. Intercooler same as above won't increase hp at all
    4. No a cam is a better option especially since the engine is already out of the car.
    I would do what neb said if you just want a quick boost in power.
  9. #9 Re: If you had $500 What mod would you do?
    Kemmerer, Wyoming
    for 500 you won't be able to do any of the above except the rocker, and I wouldn't suggest those. intercooling is going to be more than 500 and a light cam won't be satisfying enough.
    best bet is to do suspension mods like front and back strut tower braces, bigger sway bars and upgraded trailing arms.
  10. #10 Re: If you had $500 What mod would you do?
    A used cam can be found for less than $200.
  11. #11 Re: If you had $500 What mod would you do?
    Cam...
    Since you already have it apart. Something like a VS/S1X/XP etc you don't have I go stupid big to enjoy a cam.
    A IC setup is gonna run more then that and can always be added on later on without much hassle. E85 can also be added later on too without much issue.
    04 Comp G.
  12. #12 Re: If you had $500 What mod would you do?
    These threads you keep making.
    Give me headaches.
    Just buy something already.
  13. #13 Re: If you had $500 What mod would you do?
    May 2012
    Where winter never ends
    S1X/XP Cam, 105 Valve Springs, New OEM Chain, tune. Do it already.
    2000 Regal - Winter Beater
  14. #14 Re: If you had $500 What mod would you do?
    May 2008
    Schuyler, NE
    Be a lawbreaker and spray it!!
    Or, hope wbs runs intercoolers for $550 this black Friday again.
  15. #15 Re: If you had $500 What mod would you do?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I say this strictly because the engine is out. Do a cam and other engine items that are hard/impossible to do with the engine back in the car. You will be glad you did.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  16. #16 Re: If you had $500 What mod would you do?
    Oct 2015
    Georgia
    I would do the beach weekend mod...
