So my father and I rebuilt my engine even though a few people have said not to. The engine was rebuilt because it spun a rod bearing at 139K miles. Following are the details of the rebuild.
Here is everything we had done to the block:
New cam bearings
New freeze plugs
Block was decked (.007" off the deck)
Main bore alignment was checked
Cylinders honed
Here are the parts that were used for the rebuild:
Stock pistons (139K miles)
Hastings piston rings
New L32 connecting rods
Rollmaster single timing set
New timing chain dampener
Reman crank (.010" under)
Clevite 77 trimetal main bearings
Clevite 77 trimetal connecting rod bearings
New oil pump
New water pump
New seals all around
Cometic MLS headgaskets (.060" thickness)
ARP head studs
New main bolts
New crank bolt
New cam bolt
ZZP Reman heads
105# crow cams spings
Modified LS retainers
Intense-Racing S1X camshaft
LS7 lifters
Probably more
The engine has 1,500+ miles on it so far and has been pretty awesome. Oil pressure is 20-25psi at idle, cruising on the interstate pressure is 55-65psi, and getting on it I see 70psi or more. While we were rebuilding the engine I had the trans rebuilt too. I sent my trans to TEP and had him do the HPS3 package with it. Dave did an amazing job and I highly recommend him. The goal of rebuilding the engine and the transmission was to make my car basically like new and not have payments.
Let me know what you guys think.
Awesome... And don't let the $500 bottom end guys make you do any rethinking... If done right, the rebuild will far outlast the body on the car, lol.
any pics?
