Thread: Backyard Engine Rebuild
Results 1 to 17 of 17
  1. #1 Backyard Engine Rebuild
    Sep 2014
    South Carolina
    So my father and I rebuilt my engine even though a few people have said not to. The engine was rebuilt because it spun a rod bearing at 139K miles. Following are the details of the rebuild.
    Here is everything we had done to the block:
    • New cam bearings
    • New freeze plugs
    • Block was decked (.007" off the deck)
    • Main bore alignment was checked
    • Cylinders honed
    Here are the parts that were used for the rebuild:
    • Stock pistons (139K miles)
    • Hastings piston rings
    • New L32 connecting rods
    • Rollmaster single timing set
    • New timing chain dampener
    • Reman crank (.010" under)
    • Clevite 77 trimetal main bearings
    • Clevite 77 trimetal connecting rod bearings
    • New oil pump
    • New water pump
    • New seals all around
    • Cometic MLS headgaskets (.060" thickness)
    • ARP head studs
    • New main bolts
    • New crank bolt
    • New cam bolt
    • ZZP Reman heads
      • 105# crow cams spings
      • Modified LS retainers
    • Intense-Racing S1X camshaft
    • LS7 lifters
    • Probably more
    The engine has 1,500+ miles on it so far and has been pretty awesome. Oil pressure is 20-25psi at idle, cruising on the interstate pressure is 55-65psi, and getting on it I see 70psi or more. While we were rebuilding the engine I had the trans rebuilt too. I sent my trans to TEP and had him do the HPS3 package with it. Dave did an amazing job and I highly recommend him. The goal of rebuilding the engine and the transmission was to make my car basically like new and not have payments.
    Let me know what you guys think.
  2. #2 Re: Backyard Engine Rebuild
    congrats!!!! making sure Main bore alignment is in order is key to the whole rebuild. i seem to recall your thread like a year ago maybe right?
    what was the final price tag on all parts? i know that had to add up.
    im yet to hear a bad thing about tep either. not surprised your super happy with the tranny....
  3. #3 Re: Backyard Engine Rebuild
    I think you did 110% of the right thing going to Dave.
    I'll say that much.
  4. #4 Re: Backyard Engine Rebuild
    Sep 2014
    South Carolina
    Quote Originally Posted by ScottyDoggs View Post
    Thanks! Sorry for the delay in reply. It ended up costing between $2800 and $3000 for the engine rebuild for parts and machine work.
  5. #5 Re: Backyard Engine Rebuild
    Quote Originally Posted by 99coupegtp View Post
  6. #6 Re: Backyard Engine Rebuild
    Buffalo
    I'm guessing most of that went to the labor and machine work. which is why most people grab another bottom end for dirt cheap.
    Just because you did something something different / doesn't mean it's wrong.
    I paid for shipping on my motor what most pay for a used motor. It is what it is
    any progress pics and parts piles??
  7. #7 Re: Backyard Engine Rebuild
    lmao. yeah thats a lot of coin.
    my top swap has a 110,000 mile short block. whole swap cost me like 400 in gaskets and porting tools. been running strong for 3,000 miles now. its getting a ic installed next week.
  8. #8 Re: Backyard Engine Rebuild
    Sep 2014
    South Carolina
    Rofl. Yeah it was a lot but I love the car so I was happy to do it. The rebuild was a lot of fun. The machine work actually only ended up costing $520. The rest was in parts.
  9. #9 Re: Backyard Engine Rebuild
    Sep 2014
    South Carolina
    Nice, where'd you find such a low mileage engine? What IC are you putting on it?
  10. #10 Re: Backyard Engine Rebuild
    funny but it found me lol
    i got the IC Ed makes and sells here used off another member.
  11. #11 Re: Backyard Engine Rebuild
    Kemmerer, Wyoming
    I bet that thing is going to have traction issues
  12. #12 Re: Backyard Engine Rebuild
    Quote Originally Posted by SgtMarshal View Post
    it already does lol
  13. #13 Re: Backyard Engine Rebuild
    Nov 2011
    NY
    • New cam bearings
    • New freeze plugs
    • Cylinders honed
    • New oil pump
    • New water pump
    • ARP head studs
    • New main bolts
    • New crank bolt
    • New cam bolt
    • ZZP Reman heads
    • LS7 lifters
    • Probably more
    Awesome... And don't let the $500 bottom end guys make you do any rethinking... If done right, the rebuild will far outlast the body on the car, lol.
    any pics?
  14. #14 Re: Backyard Engine Rebuild
    Sep 2014
    South Carolina
    Had troubles with uploading pictures so I created a OneDrive album. I couldn't find all of my pictures either but here are some of them:
    https://onedrive.live.com/redir?resi...thint=album%2c
  15. #15 Re: Backyard Engine Rebuild
    Oct 2015
    Just curious did you have everything balanced? (Crank, rods, pistons, rings, and bearings) maybe that's not of concern with a stock 3.8 but whenever any parts get swapped in my v8 motors it all gets weighed and parts matched down to less then a gram then balanced at the engine builder.
    Sent from my SM-G900T using Tapatalk
  16. #16 Re: Backyard Engine Rebuild
    Sep 2014
    South Carolina
    Quote Originally Posted by 01buickregalsc View Post
    I asked them to balance the connecting rods but I don't think they did as it wasn't on the bill. I didn't ask to have anything else balanced though.
  17. #17 Re: Backyard Engine Rebuild
    Banned
    Jan 2013
    Colorado
    geez you could get a few grand prix's for that price
  1. Low engine vacuum at idle after engine rebuild
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2013, 11:51 PM
  2. 3.8L V6 Engine Rebuild
    By GoBlueDawson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2012, 07:49 PM
  3. 3.8L V6 Engine Rebuild
    Last Post: 11-16-2012, 12:59 PM
  4. Possible Engine Rebuild?
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2012, 02:48 AM
  5. Engine rebuild kit
    By dipset1413 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2012, 07:53 AM
