The socket should go in if you start on the drivers side and slide it in there. Use an extension with the swivel tip and you will have the clearance you need. The bigger problem is removing the actual knock sensor. It won't fit through the opening so take it up over the top of the transmission and fish it out with a magnetic telescoping whatchamacallit through the passengers side wheel well. Your going to need to remove the wheel.
Jeff
