Thread: 2005 grand prix help engine problems
Results 1 to 5 of 5
  1. #1 2005 grand prix help engine problems
    Aug 2015
    michgan
    when i cold start my car it'll run fine until it gets hot then it runs rough nd the trans will start shifting hard. i have a check engine light on for gas cap and thermostat. it also only gets hot when I'm driving it. it'll cool down when parked with ac on. the broken thermostat usually kept the car cooled down cause its stuck open but now that its summer time and its like 90 out its not helping. hottest it ever got was bout to 2 lines from the red lines nd it was acting like it wanted to die. fluids are all full. no oil in the coolant. just got to 170k
  2. #2 Re: 2005 grand prix help engine problems
    I'd replace the thermostat before you overheat it and do some damage.
    If the car runs fine at normal OP temps then that will be good.
  3. #3 Re: 2005 grand prix help engine problems
    Aug 2015
    michgan
    it don't run fine at normal temp tho. the broken thermostat kept it at half the normal temp and that was fine until it got hot out. I'm going to replace it just haven't really had time and wanted to figure out whats going on with my car.
  4. #4 Re: 2005 grand prix help engine problems
    SE Level Member qroberts16's Avatar
    Aug 2015
    Start with replacing your thermostat and cleaning the maf. Sensor
    Sent from my VS986 using Tapatalk
  5. #5 Re: 2005 grand prix help engine problems
    Aug 2015
    michgan
    replaced the thermostat today and same thing is happening. the old thermostat still looked good too.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 11
    Last Post: 08-05-2015, 08:17 PM
  3. Replies: 184
    Last Post: 03-30-2014, 07:51 PM
  4. 2001 Grand Prix Engine Problems HELP!!!
    By dammann in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2012, 09:50 PM
  5. 2005 grand prix problems
    By jamal313 in forum General Tech Discussion
    Last Post: 02-03-2012, 08:41 AM
