Thread: porting l36 LIM
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: porting l36 LIM
    Yes..but to tell you which side it's thick or thin, you want the gasket.
    I remember when that write up first came out, I questioned that item and unfortunately it was not received well. In the end though..if you make it 1.9 and square things up a bit, you aren't helping yourself unless you work on the edges that will give you benefit.
  2. #22 Re: porting l36 LIM
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    what do you mean work on the edges exactly? like taper them?
    how would you go about porting a LIM?
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #23 Re: porting l36 LIM
    Apr 2015
    Columbus, OH
    He's right because castings can shift. Some I guess worse than others. Don't gasket match it unless you are gasket matching your heads. But laying the gasket on will let you see if you have any shifting.
    Also you can bolt the lim back on with your old gasket and stick your fingers down the runners. You'll be able to feel which sides are safer to trim.
    Top Swapped 01 Imp
  4. #24 Re: porting l36 LIM
    St Thomas Ontario
    was hoping to do this with a extra LIM so there is no downtime, but i am sending my pcm to overkill for the gear ratio change, guess i can spend my time porting and test fitting then.
  1. TB porting
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2011, 07:39 AM
  2. L36/L26 lim porting
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-12-2010, 09:32 PM
  3. porting
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-27-2010, 04:27 PM
  4. Porting Gen 5 M90
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:38 AM
