Thread: Bottom end question
Results 1 to 19 of 19
  1. #1 Bottom end question
    GT Level Member bachert24's Avatar
    Jan 2015
    Dropping off my L36 at the machine shop pretty soon to get it cleaned up before I rebuild it. I'm planning on throwing a bunch of N/A power goodies at it (I know supercharger is better, but that's not what I'm doing) so I'm wondering what I should do with the bottom end. I'm assuming the crank is plenty strong enough so I'm wondering what I should do with the pistons and rods. I can't afford diamond and I'm certain they are overkill anyways. I'm expecting about 300-350 hp at the crank. I thought I read that I could L26 rods and L67 pistons but im afraid the stroke would be off without knowing the measurements. You guys have any real world advice? If note: I cleaned up the combustion chambers on my heads so with the metal removed I am losing some compression. I would like to be around 10-10.5:1 so I can run 87 octane still. My head gaskets are cometic .051 gaskets. Let me know what y'all think.
    Sent from my Sprint LG G3 sexiness via tapatalk
  2. #2 Re: Bottom end question
    best advice is to not bother. last guy who modded up a n/a engine was rather upset at the dyno.
    leave the bottom end alone, buy a turbo. or do nothing, cause the gains are not worth the cost modding a n/a engine.
  3. #3 Re: Bottom end question
    hangover park IL
    the only NA setup that would be worth putting the time and # into would be a real high compression domed piston (custom pistons) setup with a big shot of spray for when 250-300ish crank hp isnt good enough fer ya and you want some actual power.
    the cam that'll give you that kinda power up top is gonna make it drive like **** at lower rpm's.
    ~James~ Psychotic Gearhead
  4. #4 Re: Bottom end question
    Jan 2015
    I have a GT1 cam, porting everything. Ill be getting a tune. I'm not expecting to set records, just want more of a kick in the seat. 350 crank hp is very achievable N/A. Again I'm not looking for opinions on what not to do with my car, just the rods and pistons. I'll likely add a turbo down the road, but it'll be a few years as I'm raising 4 daughters.
  5. #5 Re: Bottom end question
    you'll never get that much hp just n/a.
  6. #6 Re: Bottom end question
    Jan 2015
    Quote Originally Posted by ScottyBDoggs View Post
    Wrong. But thanks for your opinion.
  7. #7 Re: Bottom end question
    not wrong, but good luck with it. its missing 2 pistons for your math to work.
  8. #8 Re: Bottom end question
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Gotta go with scotty. I believe on club gp they have a thread where the n/a dyno record is like 250. Which would only be like 320 ish on a good day crank.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  9. #9 Re: Bottom end question
    Jan 2013
    Raleigh, NC
  10. #10 Re: Bottom end question
    hangover park IL
    Quote Originally Posted by bachert24 View Post
    JE wanted 900 for dome 3800 pistons and they already make OE dish pistons so they have the file/programs.
    youd have to mill the **** out of the heads and remove all the MLS layers aside from the top and bottom to get close to a high compression ratio with any oe dish or aftermarket dished piston and that's at 0.000 quench practically....youll be nearly smacking the head with the piston crown.
    gt1 wont do much of anythingand youll still be held back over 5500rpm.
    don't forget that the SII 3800 even with the longer L36/26 (NA) rods have a horrible rod/stroke ratio and the resulting geometry means poor cylinder filling at high rpm that can really only be fixed with with something "assisting" airflow.
    with that cam and an oem dish/chamber limiting you to 9.6ishto1 compression ratio id say youll be at about 240 crank
  11. #11 Re: Bottom end question
    Jan 2015
    Chrsmi1 read post 3 on the second link you sent me. Thank you for proving me right. Also remember my car is a couple hundred pounds lighter and is rwd. People put your pride away and stay on topic, I'm not looking to see who has a bigger wee wee, I'm asking about rods and pistons. If you're looking to be right call zoomer and Vanessa over at zzp and tell them how you feel about it. Again, stay on topic!
  12. #12 Re: Bottom end question
    Jan 2013
    Raleigh, NC
    Chrsmi1 read post 3 on the second link you sent me. Thank you for proving me right. People put your pride away and stay on topic, I'm not looking to see who has a bigger wee wee, I'm asking about rods and pistons. If you're looking to be right call zoomer and Vanessa over at zzp and tell them how you feel about it. Again, stay on topic!
    Well Good luck then bud. Start a member thread so we can keep up with the progress. Hope you hit your goal.
  13. #13 Re: Bottom end question
    hangover park IL
    you were talking about putting l67 pistons on NA rods so I naturally assumed that you hadent done any real in depth research.
    without custom pistons your not gonna get ove 9.6/7 to 1
    the old zzp car had a custom set of pistons and if I recal it was pretty well gutted
    your still looking at making your 200hp/v6 into 240ish so its nothing to sneeze at but you wont get to 300 without dumping cubic dollars into it that you could top swap a stock NA shorty for 500$ and pull 260 crank readily
  14. #14 Re: Bottom end question
    Jan 2015
    Quote Originally Posted by Turbocharged400sbc View Post
    Only issue with that is I can't top swap on a camaro, too much customization dollars.
  15. #15 Re: Bottom end question
    hangover park IL
    welding up a TB plenum elbow to fit would seem to be a far cheaper option than custom domed forged pistons
  16. #16 Re: Bottom end question
    http://www.grandprixforums.net/threa...g-back-Teasers!
    04 Comp G.
  17. #17 Re: Bottom end question
    Jan 2015
    Think so? I suppose it's worth looking into. I think the holden 3800 has a rwd s/c version. I wonder if I could get my hands on one, and more importantly, how much customization for that?
  18. #18 Re: Bottom end question
    hangover park IL
    the holden sc housing bolts on just like ours, same LIM/gaskets
    fullthrottlev6 has at least one or two builds with US housings and a tb elbow
  19. #19 Re: Bottom end question
    Jan 2015
    Thanks!
  1. Replacing L67 bottom end for L26 bottom end
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:05 PM
  2. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  3. Question: Rear seat (bottom assembly)
    By Kuriclick in forum General Tech Discussion
    Last Post: 08-26-2009, 09:31 PM
  4. QUESTION: BRAKES; Top or bottom BOLT?
    By tygt in forum General Tech Discussion
    Last Post: 03-25-2009, 12:24 AM
  5. Out The Top or Through The Bottom
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 01:07 PM
