Thread: Have to leave the key ignition in the On position
Results 1 to 12 of 12
  1. #1 Have to leave the key ignition in the On position
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    What does it mean when I have to leave the ignition in the On position and wait a few minutes for it to start up
  2. #2 Re: Have to leave the key ignition in the On position
    Sep 2014
    Worcester, MA
    What happens if you turn the key to the "start" position?
  3. #3 Re: Have to leave the key ignition in the On position
    Sep 2014
    New Orleans
    No start but after I leave it in the On position for some minutes it starts up
  4. #4 Re: Have to leave the key ignition in the On position
    That is odd..
    If it were fuel related, it should take more than one key on to get pressure built up. But the pump runs for 2-3 seconds at most to do that. Then it stops.
  5. #5 Re: Have to leave the key ignition in the On position
    Bad ignition switch maybe.
  6. #6 Re: Have to leave the key ignition in the On position
    St. Louis
    What happens when you hit the key to try and start it? Does everything electrical go dead?
  7. #7 Re: Have to leave the key ignition in the On position
    Sep 2014
    New Orleans
    No.
  8. #8 Re: Have to leave the key ignition in the On position
    Sep 2014
    New Orleans
    But last night it did kill on me when I was just idling. All my electrical accessories was still on when it stopped running
  9. #9 Re: Have to leave the key ignition in the On position
    It turns over, but won't actually start is what you are saying. ??
    are you turning the key off at all and then going forward again at all or letting it lay there for a minute and then it'll fire?
  10. #10 Re: Have to leave the key ignition in the On position
    Sep 2014
    New Orleans
    And I had to wait a few minutes and give it some gas to start it back up
  11. #11 Re: Have to leave the key ignition in the On position
    Sep 2014
    New Orleans
    I'll cut it all the way off and then turn it to the on position and let it stay for at least one minute then it will start up. It doesn't happen all the time just started today
  12. #12 Re: Have to leave the key ignition in the On position
    Sep 2014
    Worcester, MA
    Can we put all the facts together? I can't do well with all of the tidbits all over the place.
    It sounds like:
    - When you turn the key, nothing happens
    - If you leave the key in the "on" position for a while (at least a minute), the car will just start itself without you putting the key in the start position
    - The car just shut off last night when idling, even though the key was in the "on" position and engine running
    BTW what year is the car?
  1. Ignition will not go back to off position
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2013, 07:49 AM
  2. Key coming out of ignition..in any position.
    By chicagochuck in forum General Tech Discussion
    Last Post: 08-05-2012, 02:44 PM
  3. Key comes out of ignition in every position.
    By LastPatriot in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 08:39 PM
  4. Ignition key, won't turn to off position
    By buck in forum General Tech Discussion
    Last Post: 01-11-2012, 12:29 PM
  5. Ignition stuck in OFF position
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 06-29-2010, 07:25 PM
