Thread: rpm gauge drops to 0 while driving
Results 1 to 13 of 13
  1. #1 rpm gauge drops to 0 while driving
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    When I'm driving my rpm gauge would sometimes just drop to 0 but it still rides good. I want to know why is it dropping to 0 I have a 97-03 grand prix gt coupe
  2. #2 Re: rpm gauge drops to 0 while driving
    Nov 2011
    NY
    If it's not stalling or running rough when the RPM gauge drops then I'd say it's a short in the wiring harness... You'll have to do some circuit tracing... Timely but easy fix.
  3. #3 Re: rpm gauge drops to 0 while driving
    Sep 2014
    New Orleans
    Where is the wiring harness located
  4. #4 Re: rpm gauge drops to 0 while driving
    Nov 2011
    NY
    Starts at the pcm and goes from there. I had same exact issue on 3.1 and after a long battle trying to find the problem, it turned out to be two wires shorted. After tracing the run and finding a spot that looked like it was rubbing, cut open the harness and found the breaks in the wires. Respliced, covered and was fixed. Not saying that's your problem, but worth a shot as the symptoms you've mentioned are similar.
    Good Luck.
  5. #5 Re: rpm gauge drops to 0 while driving
    Sep 2014
    New Orleans
    Where is the pcm
  6. #6 Re: rpm gauge drops to 0 while driving
    Sep 2014
    New Orleans
    Where is the pcm located
  7. #7 Re: rpm gauge drops to 0 while driving
  8. #8 Re: rpm gauge drops to 0 while driving
    that sounds a lot like your crank sensor going bad, one day it will stall from it.
  9. #9 Re: rpm gauge drops to 0 while driving
    Sep 2014
    New Orleans
    How to replace it
  10. #10 Re: rpm gauge drops to 0 while driving
  11. #11 Re: rpm gauge drops to 0 while driving
    Sep 2014
    New Orleans
    Is it called crankshaft sensor
  12. #12 Re: rpm gauge drops to 0 while driving
  13. #13 Re: rpm gauge drops to 0 while driving
    Nov 2013
    Wisconsin!
    Most likely a crank sensor unless can find a wire harness issue......good luck as tracing the harness is a biotch
  1. RPM drops while driving
    By Snoop dogg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2013, 07:02 PM
  2. RPM Gauge Drops to zero and Trac Off light turns on...
    By Treho54 in forum General Tech Discussion
    Last Post: 08-08-2012, 05:21 PM
  3. RPM drops above 45 mph
    By guyute85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2011, 01:58 AM
  4. rpm drops
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2011, 06:16 PM
  5. Losing RPM Gauge while driving!
    By fuzzy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 03:01 AM
