Thread: intake conversion questions
Results 1 to 7 of 7
  1. #1 intake conversion questions
    GT Level Member mikejohnlewis's Avatar
    Jul 2014
    Manchester, Iowa
    I have a 2002 GT coupe NA and im unsure about a top swap right now, i'm looking at this http://shop.zzperformance.com/store/...onversion.aspx
    im not sure about the benefit but ive been told its a good thing to do.
    also do I use these for this kit: http://shop.zzperformance.com/store/p/115-ZZP-Billet-Fuel-Logs.aspx
    any input on this? im also camming it with a gt cam and some other stuff along with it.
    1997 Grand Prix GT 3.8(SOLD)
    2002 40th Anniversary Coupe GT (SOLD)
    2000 Daytona Coupe GTP (Summer Car)
    2011 Ram 1500 (daily)
  2. #2 Re: intake conversion questions
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    intake conversion is for turbo setups not supercharger setup
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #3 Re: intake conversion questions
    You already have that intake manifold. :\
    Get one of these: http://shop.zzperformance.com/store/...ke-Insert.aspx
    Delete EGR, attempt to port match an L67 TB, 1 5/8 headers, etc.
  4. #4 Re: intake conversion questions
    Jul 2014
    Manchester, Iowa
    I know this im not doing a top swap, I was just curious about this, if I could benefit from it
  5. #5 Re: intake conversion questions
    No Mike.. you won't benefit from that, because it gives you an intake manifold that you can't use, an upper intake manifold that you already have and an HV3 insert that you might benefit from at the higher rpm.
  6. #6 Re: intake conversion questions
    Jul 2014
    Manchester, Iowa
    but could I use this? would it allow me to keep an N/A motor and use the billet fuel rails and n* tb? its more because I want the billet rails than anything.
  7. #7 Re: intake conversion questions
    No, the kit retains the L67 cylinder head. You do not have L67 heads. Therefore your injector ports are in the LIM. the L67 ports are in the head.
  1. 3.8L V6 SII Upper Intake L36 to L26 Conversion
    By cazanowick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2014, 07:37 PM
  2. intake questions
    By python1986 in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 08:17 PM
  3. L32 to L26 intake conversion
    By michael152354 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-08-2011, 06:16 AM
  4. Intake questions
    By GMFI in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2009, 04:47 PM
  5. questions on HID conversion kits
    By duffman87 in forum General Tech Discussion
    Last Post: 06-22-2009, 09:35 PM
