Thread: no power temp climbing
Results 1 to 12 of 12
  1. #1 no power temp climbing
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    Hi everyone
    I desperatly need some help
    2002 Gran Prix, 3.8L non supercharged
    total lack of power...high idle (1300 rpm).....seems like any grade or hill...and I can't keep the speed....transmission kicks down, but engine loses speed...no power.....has slowed from 60mph to as low as 30mph
    new spark plugs (bosch +4s) and airfilter about 6000 miles ago
    power problem seems more recent......
    changed the gas filter last week thinking that was the problem....no change
    I haven't been getting a code....but checked and found po404....egr valve......changed the valve...cleared code.....
    no change problem continues...and code returned
    ideas please?
  2. #2 Re: no power temp climbing
    St. Louis
    First off, get those platinum plugs out of there and stick some stock Irridiums in it. These cars hate platinum plugs and eat them. Did you change the plug wires when you did the plugs?
    Beyond that, could be a clogged cat or a vac leak, or both. You didn't say how many miles are on it so that may help us.
  3. #3 Re: no power temp climbing
    Sep 2014
    132000 miles
    plug wires are as far as I can tell original
    now getting a idle surge.....
  4. #4 Re: no power temp climbing
    Sep 2014
    just wanted you to know the major demon has been cleared....it went like this.......catalytic convertor was plugged....caused extra hot backflow thru egr, which burned a hole in the upper plenum causing a vacuum leak.....I got suspicious when after changing the cat con, I still had really bad surge....changed throttle body gasket...no improvement....could just barely get it running had a buddy listening under the hood, and found I had another intake leak....the burned plenum.....patched it (the 2 holes were fairly small) with JB weld it's working very well now...back to pre plugged convertor in terms of pwer and running quality......still getting engine code PO405 and 404....more to work on
    p.s. egr valve is new also...about400 miles on it
  5. #5 Re: no power temp climbing
    the cel flash when you floor it?
    last known tune up?
    whats the miles on it?
  6. #6 Re: no power temp climbing
    Sep 2014
    132000 miles
    yes did cel flashing
    tune up...plugs airfilter,,,about 3000 miles ago
  7. #7 Re: no power temp climbing
    i skimmed the plugs, get some iridium plugs in there for sure.
  8. #8 Re: no power temp climbing
    Bastard Reptile's Avatar
    Kansas City, MO
    The decel and lack of power makes me think the converter is clogged.
    Plugs won't make a difference in idle speed.
  9. #9 Re: no power temp climbing
    Sep 2014
    thank you
  10. #10 Re: no power temp climbing
    Sep 2014
    Hi Reptile
  11. #11 Re: no power temp climbing
    change the plug wires. see if that helps. if not it could be a clogged cat.
    only two thing make the light flash. need of a tune up, or clogged cat.
  12. #12 Re: no power temp climbing
    Sep 2014
    Hi Scotty just wanted you to know the major demon has been cleared....it went like this.......catalytic convertor was plugged....caused extra hot backflow thru egr, which burned a hole in the upper plenum causing a vacuum leak.....I got suspicious when after changing the cat con, I still had really bad surge....changed throttle body gasket...no improvement....could just barely get it running had a buddy listening under the hood, and found I had another intake leak....the burned plenum.....patched it (the 2 holes were fairly small) with JB weld it's working very well now...back to pre plugged convertor in terms of pwer and running quality......still getting engine code PO405 and 404....more to work on
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. Intake temp vs coolant temp.
    By chicagochuck in forum General Tech Discussion
    Last Post: 09-30-2012, 08:44 PM
  3. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  4. No power on acceleration when up to temp.
    By ABeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-21-2011, 05:32 PM
  5. Temp Climbing
    By Neanderthal in forum General Tech Discussion
    Last Post: 06-28-2010, 11:12 AM
